DriveRackPA===>>GUI
edited January 2009 in PA General Discussion
assistance needed. i found out over the weekend that using the gui will allow me to set up/make changes easier. reading some of the posts, i have some concerns.
does the gui work with driverackPA? if so, which one do i download?
i use a mackbookpro. is the software compatible? if it works with mac, what cables do i need to interface?
super thanks...
djsd
  • Driveware is Windows(r) only. If you Macbook will run Windows applications.....
    DRPA does not have a port, so can't use Driveware.
    However, if you can run windows applications, then it is a good learning tool to download the Driveware for the 260 and play around with it. It will really help you \"see\" what is going on in the DRPA. (might even make you buy a 260, 10 times the machine for less than double the price ($700).
  • No, sorry...the GUI is for the 240, 260, 1200 series, and the 480 series. Also... unfortunately the Mac does not work on the Driverack platform. Check out the READ ME FIRST BEFORE POSTING section...especially the FAQ section...
  • Sorry.. BTW Harmon does not monitor this site...So if your looking to get sponsored (I've never heard of anyone getting a DBX sponsorship) you will need to contact them directly...
