Some Info & Oppinion on Replacing SUB's (maybe useless)
Well, We/I recently cooked one of our two EV Eliminator-i Sub 's. I decided to replace the basket or possibly recone the speaker; after doing extensive research on-line and over the phone I decided to replace the whole driver. I had to take into account the EV box is tuned at 50Hz (how wierd is tat for a sub), the volume of the box (7.9 cu ft), the excursion of the cone, and a 'pseudo-folded horn\" setup. I realized that I would keep destroying the drivers if I used the stock EV 18\" (they were a bad choice from day one) so I looked at a bunch of manufacturers subs and ordered 2 from Eminence (KiloMax 18) and 2 from Peavey (LowMax 18). After installing 1 KiloMax into one of the boxes and 1 LowMax into the other box, all I have to say is WOW!, I'm returning the other Eminence KiloMax and inatalling Peavey LowMax's into both boxes, I was able to get 108DB +- 3 DB at 1m at 39 Hz with the signal being generated from my Laptop running through the mixer and amp. I bet if i do a bit more research and mod the enclosure with a port or two i'd get even better low end response due to the original tuning of the box.
---A word to anyone looking to swap out drivers on the EV Elimonator-i Sub... Have skinny arms and the back 3 Hex Head screws are easier to remove from the back (remove the input plate/crossover) it'll save at least an hour of cursing and scratched up arms.
HAPPY HOLIDAYS!!!
HAPPY HOLIDAYS!!!
*****WARNING******
The DL18MT has a Compliance Equivalent Vol. (Vas) of 20.5 cubic feet!!!...the Killomax is 8.47 cu ft....A terrible choice for the EV box, the Low rider is 14.24 cu ft and a little better match... but FAR from perfect... I like that driver ...it's way superior to the BW series...and not even in the same league with the DL18...BUT you are going to have problems with XMAX (Maximum linear excrusion) the idea in a properly designed box is to have the design limit the XMAX... by damping the cone...with the difference in VAS you will be able to overexcrude the cone and it can then hit the mechanical stops (back magnet plate) which WILL destroy the speaker...
BTW its not unusual to design a sub with a 40-55 hz design.. thst doesn't mean the thing won't have response below that...that is a manifold design... BTW here is the spec sheet for the DL18
http://www.eviaudio.co.jp/download/pdf/ ... mt_eds.pdf
I never liked the Eliminator line...that much...
WOW, I didn't realize I'm going to have to study the physics of sound when I got into the PA end of th band. LOL!
I guess I'll download (it was an alpha release of some sort) the software I had recently seen on the PSW forums and get with my father-in-law (cabinet/furniture maker) and have him help build me a box capable of handling a dual 18" set up... I
n the mean time would adding or reducing the top or bottom ventilation help out my situation? I don't have a clue...
BTW- as far as 18" drivers go, you mentioned the LowRider "isn't event in the same league" as the DL18MT. Is that a good thing or a bad thing?
What are you fav's when it comes to Drivers (HF/MF/LF)?
Thanks again!
Gary
manifold technology... I have a design for the older EV S181's with an improved box design and driver...I LOVE the Peavey Lo rider.. they ROCK! no comparison to that low budget piece of crap EV... which brings up another concern...That cabinet might not be able to take the extreme asskicking that the Lo Rider will give it...and that's no kidding
Ok so you want a new subwoofer design.. DIY? you didn't know I'm a speaker builder.. :?: Hmmmm :roll:
Well, the most awesome speaker you'll ever be able to afford (but they are a serious BITCH to build...is the LABsub...MAN do they kick ass!!! But \"BIG\" and 'HEAVY' ...They are a horn loaded design that are 45X45X24 and go nearly 200 lbs...I'll give you a link if you want...REAL response into the 20 hz range with 4-6 of these... and thats CRAZY!!!We did 6 and you could FEEL them hit a half mile away...I mean CHEST THUMP!!!!
But I have a design for a 15\" and 18\" sub... single boxes... that REALLY kick ass...Here is the 18\" design:
http://www.fane-acoustics.com/pdfs/Cabi ... ch200L.pdf
you could easily combine 2 for a 218 design... but singles load and lift WAY easier...
Here is the driver I recommend....
http://www.loudspeakersplus.com/html/c1 ... specs.html
@ loudspeakers Plus they were under $150 last I looked
Here is the 15\" version:
http://www.fane-acoustics.com/pdfs/Cabi ... ch125L.pdf
and the P audio C15 EL driver
these were $120 when I bought them this fall...and will nicely replace the Fane Colossus XB drivers that are no longer available...
For the performance difference...the 15\" ones do exactly the same as far as specs...so for the size and cost difference...I went with the 15's...I have had guys in Sweden, and now Australia build them.. a dnthey were blown away...the guys in Australia said they had to go to the dentist after they auditioned them because they knocked their fillings loose...
try em... you'll love em! 2 is good.. 4 is great... 6 is insane.. and 8 is DEVASTATING....
http://viewmorepics.myspace.com/index.c ... mId=993372
Thoroughly recommend them and as I'm no longer 21 and bullet proof, their relative light weight and compact size are a bonus.
Here's the tail end of the thread, just as we got the subs running. Good luck. http://www.dbxpro.com/Forum/viewtopic.p ... c&start=30
I'd love the plans for the LABsub in the Dual 18\" variety. My father-in-law has accepted the challenge; though he is a expert cabinet maker... The LABsubs I have seen in the past are of the 12\" variety and I loved their sound but I couldn't imagine dual 18\"s in the same type of set-up.
Thanks Again
Gary
BTW- would lengthening the depth of the port at the top of the Eliminator help it out at all... Man, I hate that I even bought two of these 3 months ago without doing the right research.
As for the eliminators... the pair with 2 Peavey 18\" Lo Riders is as good as it gets...no modifications of that box will help anything... :shock: sorry...
WOWOWOWOW, over the holiday my Father-In-Law and I built 10 of the 18\" Constructor series. and all I can say is \"WOW!\".
I took my holiday bonus and spent it on 8 more Low Rider Drivers and 3 Crown XTI 4000 power amps and the required plywood & hardware.
Under our KF695's they are insane!
Thanks for the help.
Just another Gary
How about some pix? and some more info...
Gary
see ya!
