Proper Gain Structure on Active Cabs
Hi Guys, I've used the Driverack PA for a little while now and have set the gain structure correctly when I was using it on a set of passive cabs with an external amp no problem. The question I have is now that I'm using a pair of QSC HPR153i's with the 181i sub how do I set the gain structure without running very loud pink noise through my speakers? Sorry if this is a noobish question but it's been eating at me all day as I've been doing a dry setup.
Jon
Jon
As I said I don't understand unless the DRPA when set to unity provides the necessary levels for the HPR...some monkeying around will most likely be necessary...
- Jon
