new guy..help
I have 4 jbls's mrx series ,,2 18 inch subs and 2 15inch monitors 2 way's
2 crown amps not sure which series but probaly the most recent,there badd ass
question 1: what it the correct setting for these ; the sub's just sound too rumbley, is there a way to get them more of a tight punch
Question 2 : I dont have the RTA mirophone yet.Is this vital to eqing your sound or enchaning the overall purpose of the drive rack pa
heres a pic of what i have without the amp..
ps when djing should i turn the sub away from me toward the crowd...
What are you using currently for settings?
Question #1 - Plug the sub ports with some expanding foam from Home Depot and definately aim the front towards you. That way you'll have plenty of low end.
Question #2 - No mic needed. Just load in MPro410's and the MPro sub. The PEQ's are preset.
The amps that you have are too big. Get some smaller ones.
Good luck. :roll: :roll: :roll:
i have the xti-2000 and 400 crown amps. I read a little in the before posting section ,,found the section about two way setup,, but it showed a rta mic ,, iam getting one ,but in the mean time just curious bout manully setting it..
