Home dbx Forum dbx Forum Archive General Configuration Wizard
Drive Rack PA with Peavey speakers and amps
edited October 2008 in Configuration Wizard
I just purchased a Drive Rack PA, and want to use it with two Peavey 1600 amps and two Peavey SP-2 Speakers (bi-amped), and with a Peavey 3800 amp and two Peavey 118's for the low end.
I am assuming that I will be telling the setup wizard that this will be a two-way system, even though it would technically be tri-amped. I realize that the wizard has the tunings for the low end amp/speakers, but what about the top side??
Thanks for the help!
Russ
  • That will be a 2X5 (mono subs), or 2x6 (stereo subs) Go to the READ ME FIRST BEFORE POSTING and read.. especially the FAQ section where your bi-amp tops are discussed.. then come back and ask specific questions...
