Unable to RTA - Not finished
hey everybody,
I have a real piece of work on my hands.
I have a 3 way system, consists of
4 - Yamaha Dual 18\" subs
4 - Carvin or Peavey dual 15\" with horns. ( i can't remember what brand)
4 - Piezo boxes. with about a dozen piezos in each box.
All of this is individually bridged by a slew of peavey amps.
So power is not a concern.
Problem is that the system is jacked up. It won't rta for anything.
They said it's hardly ever done it.
I have to go rewire the whole thing because the previous sound guy unhooked the horns from the dual 15's and has them run into a daisy chain with the piezos. As far as I am concerned the piezos are headed for the trash can.
Other than that I am trying to find some sort of help in getting a system configuration setup for this.
Are there any profiles or anything to help me setup the DRPA with the appropriate speaker types?
Also would you think that the piezo cabinets are necessary?
I got a long way to go and a lot of questions in getting this system right. Luckily it's not mine, it's for a local band.
But what would cause it to not do an rta? Something more than 12db out of whack?
  • You STILL need to include ALL the info...amp, models and number, speaker type, model and info, do you want to bi-amp the tops? ETC
    Two things can cause that message.. more than 4 bands 12 db out of whack as you say...OR you have chosen dual mono and not stereo linked, so it wants to do the other channel...
    Go to the READ ME FIRST BEFORE POSTING section at the to of the page and look through the posts,, and the FAQ's...
