Home dbx Forum dbx Forum Archive DriverRack PA & DriveRack PA+ PA Connectivity
Low power adjustments
edited September 2008 in PA Connectivity
Hello guys,
As you guys suggested I have bridged the crown 402's (one to each jbl18s). I am using the crown 602 for tops (jblpro 215's) Very noticed increase in the subs and tops.
One question as I have read a couple places , since my system is in the drpa and I let the wizard set it up does it set the gain structure for me?
Also setting the drpa amp levels to the power amps in the wizard,do I set them as shown by the wizard or do I set the drpa amp levels to the amp level of my choice? And what level should I set amp as I know full out is not the way to go.
Confused a bit but learning as I go :roll: :roll: .
Thanks for the knowledge,Boog
