260 WIZARD SET UP
my current setup 2-3 way custom made tops 12\" -lows,8\"-mids,1\"-highs
4-12 hornloaded cabs
1-QSC RMX 850-HIGHS STEREO outs 1-2 3.5k and up
1-QSC RMX 850 -MIDS STEREO outs 3-4 500-3.5k
1-QSC RMX 1450- LOWS MONO out 5 100-500
2-QSC RMX 1450-SUBS BRIDGED MONO out 6 35-100
none of the user presets have a setup like this so i did a new configuration by holding the configure button and it worked but the problem is that the configuration nevers asks for what amps and levels they are set at is there away to configure amps and levels with out using the wizard or can i set up a user preset in wizard mode and set the x-overs to my needs :?
Go there and do that. It should shed light on what you are wanting to do.
