Driverack PX and RCF Art525A
Hi, I have a Driverack PX and a pair of RCF Art525A's. How can I configure the Driverack PX with these speakers, as I've noticed there are no presets for these speakers in the Driverack PX. Thanks in advance. All help is greatly appreciated.
You also need to read the \"Read me first before posting\" section... lots of goodies there...
ACOUSTICAL SPECIFICATIONS
Frequency response 45-20Khz
Max SPL 131dB
Sensitivity 1w/1m -
Coverage angle 90°x60°
Compression driver neo 2\"
Midrange -
Woofer neo 15\"
Power handling -
INPUT SECTION
Input signal- Impedance bal/unbal
Input connector jack/xlr
Output signal connector xlr
Input sensitivity 0dBu
Mic. input sensitivity -
PROCESSOR SECTION
Crossover frequencies 1200Hz
Selectable high pass output -
Protections DC/short cir.
Limiter fast/rms limiter
Master volume yes
Phase switch -
Music/Voice eq -
Remote control option -
AMPLIFIER
Nominal power 750 Watt
High frequencies Digital 250 Watt
Mid frequencies -
Low frequencies Digital 500 Watt
Cooling Convection
PHISICAL SPECIFICATIONS
Height 680mm (26,77\")
Width 405mm (15,94\")
Depth 345mm (13,58\")
Weight 18.5 Kg
Cabinet Composit PP
Hardware 4 M10 flying points
Handles 2 side, 1 top
Pole Mount / Cap yes
Colour Anthracite grey
Thanks.
If you want to lrearn why, or what the other features are, and how to best use the you need to read the RMF section as I said...
GADGET
