223XL Crossover...help with settings
Hello to all, Im new to the forum and recently purchased a 223XL Crossover. Im new to the whole PA things so Im asking those who know.
I have a Mackie 2500 that im using to push two Peavey 215 cabs, and a
Mackie 1400 that im going to use to push two Peavey 118 subs bridged.
Should i set the 223 to stereo 2-way mode or mono 3-way mode? What is the difference between the two? Also, what about the mono/stero button on the rear, what shoyuld be set to depending on the mode?
help help...
help help...
3-way is used if you are bi-amping the tops (which you are not).
Hope ths helps.
also the 40hz cut should be on channel 1 the low channel right
thanks again, im idioit with this
LF Sum = Summed (In)
40hz cut = On ( Channel 1, actually both channels can be on, but it doesn't matter)
