Px Problems
Our band recently purchased a DRPX. We used twice. Used most of the tips we got off of this forum and was extremely pleased with the results, however upon setting it up for a gig last night the unit would not turn on. What could have caused this? The last 2 times we used it it worked fine. Is there an internal fuse somewhere that may have blown?
We have been using it with 2 JBL EON15G2 tops and a mono JRX118SP sub. Any info would be greatly appreciated. We have heard how awesome our system has sounded with this unit and are completely devastated that it didn't work last night. Help!!!
BTW if the hard reset fixes the problem you need to look at the power you send the unit...you might want to invest in a UPS (uninterruptable power supply) that will keep it powered even when brown power (that below the units minimum power requirement)
No man it was the cord itself that went bad. We make it a point to get wasted AFTER everthing is set up not before to avoid stupid mistakes like forgetting to plug something in.
Thanks for all you help!
My $.02.. I have 4 driveracks and THOUSANDS of on off cycles and 5 night a week duty for some for 8 years and never a glitch after a sofware upgrade for a 260..granted I have only had the PX for a time but it is out every week and chuggin right along...
