Greetings gents. I would like to adjust my GEQ left and right channels seperately. I cant find a way to do this. Is this possible? If so...sorry for asking a stupid question. :roll:
When you do a system set-up in the wixard, it will ask you how to set up the GEQ. Select Dual Mono. The phrase is sort of counter intuative, but it is in fact 2 separate mono sources, which IS stereo.
The manual could be much better, OK... a lot better.
Thanks for that tip fellas. I have been away and havent been able to take a look at doing this yet. When going into the Wizard to do this will I then need to re-adjust everything or will it allow me to change ONLY the GEQ into this mode? I dont wanna mess with my other settings as I needed someone to walk me through the entire set up process. Thanks again.
I am not sure if the x-over, limiters, PEQ's, etc will be lost, so I'd copy everything down, just in case.
Be sure to post back if the info is lost or maintained. That is good info for the board.
