Using PA for Monitor Mix
edited August 2008 in DriveRack PX
As stated in my last post. I have recently upgraded my PA system to powered speakers and the driverack PX. I have been using my Driverack PA on my monitor mix by using the mid outputs but am wondering, does the PA provide the capability to make all of the outputs full range to provide a better monitor mix?
I see that section 2.5 \"Navigating the Xover Section\", says that I'm able to edit the parameters of the crossover but I'm not in front of my unit right now and wanted to know if indeed I'd be able to edit each of them considerably. Preferably 80Hz to 20kHz.
  • You can use any out put as \"full range\". You just have to set up the x-over section to use all outputs. In orther words... set up a 2 x 6 (bi-amp with stereo subs). However, use the Hi outs because you will have an extra PEQ filter. Any used output can be bandwidth adjusted to \"full range\".
  • That's odd. I received a message saying that I could connect and that the reply was not sent. Tried 3 times. Same message. Yet... here it is.
    hum :?
  • Still getting this message. Yet....
    Could not connect to smtp host : 10060 : A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    DEBUG MODE
    Line : 111
    File : smtp.php
  • Um Dra..
    This is a PX 2X4 is the best you can do and yes, filters can be set for all or part of the frequency spectrum, simply set the HPF where you want it.
  • :roll:
    But if you could set up a 2x6, that would be way cool. 8)
  • Thanks Dra. One of the Guitar Center guys and I actually went through it as well. Gadget, it is a PA we're talking about.
  • Weird... very disorienting...I could swear the post was in the PX forum? Oh well.. the same still applies.. at least as far as the outputs, they can ALL run full range, or partial, by setting the HPF.
  • I think it was a PX, then somehow (maybe because we were thinking that it was a PA) changed itself to a PA, trying to be special. :lol::lol:
    Gadget, got an answer for me on my 260 output problem?
  • Now I am getting this message...
    Ran into problems sending Mail. Response: 500 5.3.3 Unrecognized command
    DEBUG MODE
    Line : 122
    File : smtp.php
    I can post fine, but replies give me these crazy errors (even though they post).
  • I have no answer Dra...Send a message to tech service and see what they they think. Did your crossover gains change somehow?
    I think they are working the bugs out of the new server...
