Subharmonic Synth
What exactly is subharmonic synthesis and what is the proper way to use it? Our band recently purchased the DRPX. Upon reading the manual I found that it only kind of mentions subharmoinc synth but doesn't go into much detail on its proper application and use.
Can you tell I am against them? just because the box has a thing, doesn't mean you need to use it!
IF you were doing only DJ work and IF you had subs that would go really low and IF you had a crazy amount of power... the sub synths could be fun...
