Full Range into qrx-212 with mono sub?
Can I run a full range setup with driverack pa into qrx 212 cabinets with a mono sub going to jbl dual 18's? If so, what perset would I start with on the dbx and what settings will need changed. Thanks for any help or suggestions. BJ
http://www.dbxpro.com/forum/viewtopic.php?t=958
http://www.dbxpro.com/forum/viewtopic.php?t=959
or:
http://www.dbxpro.com/forum/viewforum.php?f=60
Because if you had you would have a preponderance of info to go on... and its a lot more than can be put in any one post...You can get a good head start here:
http://www.dbxpro.com/forum/viewtopic.php?t=960
http://www.dbxpro.com/forum/viewtopic.php?t=1196
You would also know that I don't recommend presets (except the ones you make yourself, and that the process is quick and fruitful..
But to answer your question ...yes it's doable...and no you didn't give enough info to give you a full answer...but do yourself a favor and do some reading then ask your questions...the benefits will be \"audible\"
Moderator
