Saving Outdoor Auto EQ settings
I have a question re: saving your settings after you have run the auto eq outside to get a baseline setting.
When the Auto EQ is completed the only option on the screen is to exit the RTA. When I press the store button nothing happens.
What is the best way to save these settings? Should I save the GEQ settings or just the PEQ?
gadget
I'm having a little difficulty in understanding how to transfer data from the GEQ to the PEQ after auto eq. I experimented with it by these steps
1. I auto eq'd outside using the o response.
2. After completed I looked at the graph, noted the spikes or dips
3. Went to the PEQ- flatten-bell shaped and then enetered a frequency. I noticed a peak at the 40 hz on the GEQ so I chose 40 on the PEQ and decreased the gain for the freq using a narrow Q. 4. and then saved it
4. I went pack to the GEQ to see if the Spike had flattened but it had not.
What should I be doing differently.?
Now , indoor, or outdoor EQ below 100 hz is suspect ESPECIALLY indoors... in fact ...indoors, anything below 170 hz is suspect...anything above 700 hz indoors is as well and should be done by ear...
As for the 40 hz thing...it could be that your speakers can't reproduce those frequencies, and so no matter how much you boost those frequencies the speaker cannot produce them..
Did you select the correct PEQ? It has to be for the output that is producing that freq.
Did you re-Auto-EQ, or just go back to the GEQ page?
