QSC HPR Setup
I have just started helping a new church plant and need some help adjusting the setup. They have a DRPA in their rack but are currently not using it. What is the best way to utilize this equipment?
We have
1 pair HPR181i
1 pari HPR152i
Soundcraft GB4, 32 channel
What is the best way to set up this system. Does the DRPA have the QSC HPR speakers listed in it for setup.
Thanks for all the help.
We have
1 pair HPR181i
1 pari HPR152i
Some quick start parameters... Which are already in the RMF section I spoke of...
use the Wizard, all custom... answer the questions as closely to what you have as possible using \"custom\" for speakers and amps ( I know you have powered speakers but there isn't a good preset for your setup).
Set up a stereo 2x4 (or 2x3 if you wish to parallel the subs) (either is fine... I'd go mono and put them right together if at all possible)
set a BW 18 filter @ 39hz HPF
set a LR24 filter at 96.4 hz LPF for the sub
set a LR24 filter at 99.2 hz HPF this is for the tops
you have NO LPF for the tops so...(it's considered to be to 'out')
READ the material....!!!!!
For this operation you need to sit down with the DRPA and press ALL THE BUTTONS and find out what they do, and how to navigate the interface...YOU CANNOT SCREW UP ANYTHING DOING THIS!!!!!!!!!!
even if you did you can reset to factory preset with a couple presses of the buttons (HARD RESET) NOTE ... this WILL wipe out any presets you have made... so be comfortable with that! Use the block diagram to get a good idea of how the flow of signal happens in the DRPA... learn what each module does, and what the parameters you can vary are... and do...
have fun! it WILL be worth it...
What is a \"church plant\"?
And here I was visualizing a church running around looking for a place to \"plant\" itself :shock: silly me...
So does this plant then \"need help\".. other than water and the occasional dung infusion? How do you know when the plant is satisfied :?: Do most plants have a favorite pre-curve? :roll: I had no idea these things went on in church... curious...
