ZonePro Designer with Vista?
I am gettting an error when I start the GUI:
\"IP Networking is unavailable. Please ensure that no other ZonePRO Designers are running\"
If I try to do a manual scan of the network it throws out the unhandled exception message below.
Of course I have checked that there are no other instances running. This only appears when i run it on Vista and not on any XP system i have tried.
Is there a workaround?
Kit
Kit
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at HMG.dbx.ZoneProLoader.NetworkingWizard.NetWiz_Next(Object sender, WizardEventArgs e) at ScbSoftware.Windows.Forms.AdvancedWizard.btnNext_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll ---------------------------------------- ZonePro GUI Assembly Version: 2.2.0.0 Win32 Version: 2.2.0.0 CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Designer/ZonePro%20GUI.exe ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- Networking Assembly Version: 1.0.2736.26001 Win32 Version: 1.0.2736.26001 CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Designer/Networking.DLL ---------------------------------------- ZonePro Assembly Version: 2.2.0.0 Win32 Version: 2.2.0.0 CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Designer/ZonePro.DLL ---------------------------------------- dbxNetworking Assembly Version: 1.0.2736.26002 Win32 Version: 1.0.2736.26002 CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Designer/dbxNetworking.DLL ---------------------------------------- System.Drawing Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- Storage Assembly Version: 1.0.2736.26003 Win32 Version: 1.0.2736.26003 CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Designer/Storage.DLL ---------------------------------------- System.Xml Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll ---------------------------------------- AdvancedWizard Assembly Version: 1.3.0.0 Win32 Version: 1.3.0.0 CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Designer/AdvancedWizard.DLL ---------------------------------------- Controls Assembly Version: 1.0.2736.26002 Win32 Version: 1.0.2736.26002 CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Designer/Controls.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging=\"true\" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
Which version of .Net Framework do you have installed? I would recommend updating if you have older than version 1.1 Service Pack 1.
Here is the link for updating.
http://www.microsoft.com/downloads/deta ... laylang=en
.NET Framework 1.1
.NET Framework 1.1 SP1
.NET Framework 3.0 (as part of vista install)
.NET Framework 3.5
Versions 2.0, 2.0 SP1 and 3.0 SP1 are not installed as they are incompatible with Vista.
Do you still get the same \"IP Networking is unavailable\" message even after you uncheck the \"Ethernet\" box in ZonePRO Designer's Properties page?
Also is there any chance of having a 31 band eq module option on outputs, i think it would greatly enhance the useability of the xonepro as it is a lot easier and user friendly to set house eq's with graphics, specially with a mouse...
Thanks Very Much for your swift reply, Merry Xmas
at this point.. may be a floating decimal point limitation for this chipset since all the lower level units have the same ones...
Why not simply de-install the Vista and re-install WIN XP? the single best operating system EVER by microsquish...the thing that really makes me angry is that vista allows micorsquish to report back EVERY KEYSTROKE! No wonder it's so slow...'Big Brother' is indeed watching.. I have done this de-install with all my computers and they are stable, fast and relatively problem free...besides...we have most of the problems ironed out with XP...
a very ANTI big brother :evil: user here in screwed up ole USofA...
Merry Christmas brother!
Gary
Kit, sorry you are having these problems. ZonePRO Designer is Vista compatible. The reason this is happening is because some other application has tied up port 3804. Send me an email to the below address and I will get you some troubleshooting information that should enable you to find the problem.
mhunter@dbxpro.com
Sorry for the inconvenience.
1) Does the DBX null modem cable use a proprietary pinout or will any null modem cable work? (we did not have access to a DBX cable)
2) Is the DBX ethernet crossover cable a proprietary pinout?
We experienced a number of connectivity problems with a single Zone Pro 1260 using SW version 2a-1.100, HW version 02. Sadly, we are unable to connect to make a simple adjustment. We tried both Zone Pro Designer 3.0 and 2.2 in both Win XP Pro SP3 and Vista, using ethernet x-over cable and a "standard" null modem cable. The unit in question is not connected to a network, so connectivity is needed only to make basic software adjustments.
Thanks in advance.
