RECOMMENDATIONS PLS
:?: Blessings>>>I have 2 JBL 125 for tops at 500rms at 4 ohms and I am using a crown XTI 2000,>>my xover setting are as follow HPF 90__BW18 LPF out
For my subs I am using JBL MRX 528 at 1000 rms at 4 ohms and I am using a crown XTI 4000>>my xover setings are as follow HPF 40 BW 18 LPF 90___LP24
Am I on point with the xover settings....Peakstop on and I did the gain structuring.
  • Given that you only have 800 watts @ 4 ohms stereo I would bump that xover point up over 100 hz, and with a peak power handling of 4000 watts on those subs you have no room for error @ 12oo watts per channel @ 4 ohms stereo, So I'd raise that HPF to at least 45 hz or set those limiters pretty tight.
    Especially if your doing live sound...
    Gadget (Gary)
