Is it ok to run all systems fullrange?
Good day,
I play in a band that is into lite jazz/dance music.
I chose a 2 way stereo setup with all outputs full range. Is that ok?
We play in a 150 sqm park.
  • Assuming that you have 6 of the same cabs (no subs), you have 2 options.
    Set up a 2 X 6 and open up all x-over bands to cover the spectrum that you want. (I recommend that you set a HPF for all outputs.) That gives you 3 stereo pairs.
    The other option is to daisy chain your amps and just set up a 2 x 2.
    PS - Now that I re-read your post, I'm not sure what you are asking. Can you be more clear on what you wish to accomplish?
  • Hi Collinnathaniel
    What Drive rack do you own???
    Are you looking at delays???
    Mark
  • Good follow-up FanMan. That seems probable, so separate outputs with their own delay is imperative. OOPS! DRPA! Delays are are out of the question.
