Help regarding setup of my DRPA with my rig...
Good day,
My name is Chris. I am from the Philippines
pines.
I have a band who plays classic lite jazz, rnb and dance music in an outdoor park with an area of 120sqm.
Please help me setup my drpa with the right configurations and crossover setup to maximize what i got.
I have:
Soundcraft Mixer EFX12/2
1 pair Beta 3 U15A as my \"High\"
Transducers    (Woofer)15LB075-U×1
    (Treb)ED4401+H4403
  Frequency -3dB / -10dB   40Hz-18KHz, 35Hz-20KHz
  Rated Power RMS   (Treb)100W, (Woofer)300W
  Dispersion (HxV)   50-100°Ã—55°(Rotatable)
  Maximum SPL (dB/M)   120dB(Free Field)
  Frequencyadjust   100Hz :±12dB / 10KHz :±12dB
  Input impedance   Balance 20K Unbalance 10K
  Connector type   mic\\line: XLR J3P / XLR K3P
  Protect Circuit   Limit Protect overheat protect,Short Circuit protect,HF Protect
1 Beta 3 U15A as my \"Monitor\".
1 Inter M Power amp CM15.5
Power output is
Stereo Rl = 8ohms 510w+510w, Rl = 4ohms 800w+800w
Frequency response rl=8ohms,P=1w 10hz~35khz(+-.5db)
Input impedance = >= 20kohms
Power consumption is 950 watts
1 pair Biema Subwoofer FD181bII
FRequency responce is 30hz-350hz
Impedance = 8ohms
Power(RMS) is 400w
Peak = 800w/5min
sensitivity = 100db(1w/m)
max. spl = 129db
I want to optimize setup according to our bands need.
How do I make the kick drum with more ooomph or low end? Is there a particular trick or twist involved?
Your suggestions will be highly appreciated. Thank you very much.
Chris
