Drive Rack-PA with JBL Array 4892 Settings
Can anyone suggest settings for the DriveRack-PA with JBL Array 4892-45 speakers with subs? I am running two plus a custom sub (loaded with 2 x JBL 2241 18\") per side.
Available amplifiers are:
JBL MPX300
JBL MPX600
JBL MPX1200
Crown K1
Crown I-Tech 6000
QSC Powerlight 1.8
Any suggestions would be greatly appreciated.
  • I need more info...don't make me look those things up... have you checked the JBL web site out? They have tunings for much of the PRO stuff. You didn't say if your Bi-amping the tops...not enough info to be of help here...You didn't read the \"Read me first before posting\" section either...
  • Apologies. Hope this is a little clearer...
    The Array series is active so it needs to be bi-amped. The JBL ASC24 stereo two-way controller that came with the speakers has a fixed crossover point of 1kHz with a slope of 24dB/octave (Linkwitz Riley) but it also has some horn EQ in there that it doesn't say much about. With a bit of tweaking I can probably work it out but perhaps somebody here has already set-up the DR-PA for JBL Array speakers and found some good tunings they could recommend???
    Just for the record, the JBL Array 4892 recommended amplifier specs are...
    HF : 300 w @ 8 ohms
    LF : 600 w @ 8 ohms
    and the amp specs are....
    JBL MPX300 - 300w @ 4ohms, 200w @ 8ohms
    Crown K1 - 550w @ 4 ohms, 350w @ 8 ohms
    JBL MPX600 - 600w @ 4 ohms, 400w @ 8 ohms
    QSC Powerlight 1.8 - 650w @ 4 ohms, 400w @ 8 ohms
    JBL MPX1200 - 1200w @ 4 ohms, 800w @ 8ohms
    Crown I-Tech 6000 - 3000w @ 4 ohms, 1250w @ 8 ohms
    Hope this helps.
  • Ok ... first some \"semantics\" those are \"passive\" speakers, if they were active they would have BUILT IN AMPS...
    Second everything you need is right here... unless you want to second guess JBL.. and I LOVE to do that...
    http://www.jblpro.com/tunings/48909192.pdf
    second row under #3 looks like there is a hi , and lo shelf, and a .4 Q -2.5 db cut @ 3.36 khz
    Also a delay on the woofer of 3.43 ms...
    Those are actually the 4892 series... the 45 delineates a 45 degree radiation pattern as apposed to the 4892-90 which is the 90 degree version which is not germain to this discussion unless we are talking array patterns....
    Are you looking for amp recommendations? use the the Crown IT for the subs, the 1.8 for the 4892 lows, and the Crown K1 on the horns...
    P.s. you won't likely find anyone with those speakers here...MAYBE the PSW...but I wouldn't bet on it...
