Input Reading on DRPA during Gain Staging
I have followed the Gain Staging as discussed here. My problem is I am plenty loud, as loud as I want to be anyways, however the Input Meters on my DRPA just register the 2 bottom LEDS and thats it. Is this ok?? I have been coached and tutored through this whole thing multiple times as you all know, and I appreciate all of the patience from you all. I just have this tremendous feeling [& my gut is usually correct] that I am not even touching the tip of the iceberg of the performance I could be getting out of my system.
The inputs dbu LED's are
+20
+15
+10
+5
0
-30
Therefore if you
Yes that's OK
This indicates that you are peaking at 0 db (Which your desk should also be peaking at.)
(Digital devises should never clip)
Recheck your gain structure (as per the manual) and as long as your amps are not peaking all is good
What do you mean by
No load enough?
Sound is poor?
Too thin?
Mark
P.S. I even provided a \"get started\" Bi-amp setup for those speakers...even IF they weren't set up for it...in the Read me first section...FAQ's...crossover points and all...
Good luck..
I setup my Panel Jack and wiring from the QSC850 and EP2500 to the Panel jack according to the drawings you sent me. So I ended up wiring the QSC850 Outputs to the Panel Jack as Stereo [which I set the QSC850 to Parallel Mode so I only have Input 1 being used that goes out Channel A & B independently]. I know that because I am running out of the Mixer Mono there is no reason for me to run stereo with anything after that, but I following the only source I had to wire the setup and you told me to wire it up Stereo so I did. I think the main reason I did it this way was so that I wasn't running the QSC850 in Bridged Mode sending all that Summed power to the Horns... should I change this to Bridged instead?? or does it really matter??
Yes I am definitely Bi-Amping the SP2s. I have 2 4wire Speakon cables going from the Panel Jack to the BiAmp Input in each SP2.
No Subs just the SP2s.
Is this a little clearer?? Is this setup OK so far??
As you said (L) hi out to the 850, (L) mono low out to the 2500...
set a custom 2X3 crossover and follow the directions in the read me first post...
gadget
31.5 = +6
40.0 = +6
50.0 = +6
63.0 = -1.5
80.0 = -1.5
100 = +.5
125 = -2.0
160 = -3.0
200 = -1.5
250 = -5.0
315 = +3.0
400 = -12
500 = -12
630 = +6
800 = -10.5
1.0k = -4.0
1.25 = +.5
1.6 = -3.5
2.0 = +6
2.5 = +3.0
3.15 = -5
4.0 = -2.5
5.0 = +3.5
6.3 = +2.0
8.0 = 0
10.0 = +3.0
12.5 = +7.0
16.0 = +10.5
If not do you have a place where you can place a speaker against a wall bu away from a corner? For this test place the speaker against a wall on the floor on a piece of carpet... place the mic about 2 feet out on axis between the horn and woofer and redo the auto eq show the curve...
That 250 , 400 and 500 hz room resonances...
The high stuff is the the CD horn (needs it)EQ and the 2k area a horn resonance...
well see when you get a different Auto EQ
Gadget P.S. send those pics of the process please...
31.5 = +5
40.0 = +5
50.0 = +5
63.0 = +4
80.0 = -1.5
100 = +1
125 = +.5
160 = -6
200 = +2
250 = -4.5
315 = +2
400 = -11
500 = -4.5
630 = 0
800 = -6.5
1.0k = -2.5
1.25 = 0
1.6 = -3.5
2.0 = +2.5
2.5 = +2.5
3.15 = -4.5
4.0 = 0
5.0 = +.5
6.3 = -.5
8.0 = +3.5
10.0 = +1
12.5 = +3.5
16.0 = +7.5
Seems its getting a little better
Note the 200 and 500 hz differences ... the 400 hz is still a room mode I believe try a little less volume also to NOT excite the room so much... I bet that room is pretty square with even dimensions... 10 X12... 8 X 10 ... 14 X 16 etc... that is what causes room modes...
Oh yeah, and those first 3 frequencies are OK where there at right, considering I have the Crossover HPF set at 50HZ??
P.S. that 250 hz is a room resonance I bet...
Yes the Driverack IGNORES (pretty much those first 4 frequencies) those frequencies that the speaker can't reproduce..even with the mic pointed at the floor to reduce the reflected energy that arrives and cancels out.. the room still sets up modes which will show up... see the \"START HERE\" post and find the \"room mode calculator\" and enter the dimensions of the room into the boxes and then see what frequencies are 1st second third and fourth in the long, short and vertical axis...
I'm glad you are experiencing the success.. now wait till you go outdoors... you won't believe the performance of a bi-tri-amped system!
Those things will ROCK!
gadget
Do the outdoor really loud, do the indoor method quieter to not excite the room...because modes will set up and the mic WILL hear them...
gadget
