which poweramp is suitable for my 700w woofer?
I am mobile Dj\\Club Dj.I have two 700W woofer and 2000w poweramp and at the 8ohm they produsce 450W per chanel.I can running this two woofer on that poweramp ?.Please help me
SPECIFICATIONS FOR 18\"LF SPEAKER
Nominal Diameter 460 mm, 18 Inch
Rated Impedance 8O
Operating Bandwidth 40 Hz- 800 Hz
Power Handling Capacity 700 Watts (rms)
Sensitivity 2.83 V, 1M 96.3 dB
Effective Piston Diameter 395 mm, 15.5 Inch
Voice Coil Diameter 99.30 mm, 4 Inch
Thiele - Small Parameters
Resonance Frequency Fs 44Hz
DC Resistance Re 5.2O
Mechanical Q Factor Qms 8.799
Electrical Q Factor Qes 0.470
Total Q Factor Qts 0.454
BL Factor BL 23.15 T x m
Effective Moving Mass Mms 178.4 gr
Equivalent Cas air load Vas 156.3 liters
Effettive piston area Sd 0.1225 m2
Voice - coil inductance @ 1KHz Le1K 0.72 mH
Half-space efficiency Eff 2.69 %
Airgap Height Hag 14 mm
Voice coil Height Hvc 25 mm
Voice Coil Over-Hung Xmax 5.5 mm
SPECIFICATIONS XP2000/XP2100 POWERAMP
StereoMode(drivingbothchannels) ContinuousAverageOutputPower Per Channel
8 20Hz-20KHz 0.03%THD 400W
4 20Hz-20KHz 0.05%THD 600W
8 EIA1KHz 1%THD 450W
4 EIA1KHz 1%THD 660W
2 EIA1KHz 1%THD 960W
BridgeMonoMode ContinuousAverageOutputPower
8 20Hz-20KHz 0.1%THD 1200W
4 1KHz 1%THD 1920W
AllModels
Inputsensitivity@8 1.4Vrms
Inputsensitivity@4 1.23Vrms
Noise
(unweighted 20Hz-20KHz below 106dB 107dB
ratedoutput)
Distortion(SMPTE-IM) <0.02%
DampingFactor > >500@8
OutputCircuitry ClassHAmplifier
Filtering Highpassfilter (30Hz,50Hz)
Selectablesubwoofer crossover at60Hz,90Hz,120Hzfor subwoofer
Subwooferoutput
output(XP2100,XP3100only)
Frequency Response 20Hz-20KHz,0/-1dB,-3dBpoints:5Hz-100KHz
InputImpedance 20K balanced,10K unbalanced
Cooling Dualcontinousvariable-speedfans,front-to-rear air flow
Connectors(eachchannel) Input:XLR&1/4\"TRSjacks Output:Speakon&bindingposts
Power:Amber Phoniclogo;Parallel:Greenbacklighticon;
Indicators Bridged:Redbacklighticon CLIP/LIM:RedLED;PROTECT:
Yellow LEDGreenLEDfor -10dB,-20dBand-40dBSignalLights
CH1&CH2GAINknobs with41detents;Selectablelow frequencycrossover
Frontpanelcontrols
at60Hz,90Hz and120Hz(XP2100andXP3100only
I am using this poweramp and two 700W woofer in a bridge mono mode.but after some time speaker was blown up.so i think its because of underpower.so i want two new speaker but which watt.please help me.
Rated Impedance 8O
4 1KHz 1%THD 1920W
AllModels
Noise
ratedoutput)
Subwooferoutput
Frontpanelcontrols
Eg model number, make etc
Qualitiy of amps make a big difference.
What type of music / band are they used for??
The answer to your question is yes BUT you are underpowered
(PS saw the change from 800w to 700w you were quick)
Make SURE they are NOT 4 OHM as in subs with 2 8 ohm woofers...
gadget
Invert the wiring on one of the speakers (one cab only), then turn that cab backwards. Place the cabs side by side on the floor. The front firing sub will pulse. As it does the rooms air flow will create a vortex. The pulse of the reverse firing sub (still to the front of the room) will exit through the unused 1/4\" jack(s) like a bullet shattering the vortex, sending a shock wave evenly to the entire room. This method (developed by the acclaimed Swedish scientist, Edghart Shloshel) has been proven to reduce the power requirements and gross number of sub cabs. The placement of the \"Shlosel Two Cabinet Max-Wave\" configuration is sensative to the dims of the room. Dr. Shlosel has developed a simple program for Windows (sorry Mac users). You can get this for less than the price of one quality sub. Only $425. PM me and I'll give you the PO Box to mail the Postal money order to.
The views expressed........ :roll:
You must do a lot of reading to have all that knowledge.
Very impessive.
A very well know scientist (Did you know that he unfortunatly died in May of 2007 (RIP)?)
Is that in US dollars?? (can I post Australian dollars?)
Sounds cheep to me!!
Have you made any money yet??
How many PM's did you get??
Mark
PS What was the model and make of speaker again??
http://www.crownaudio.com/pdf/legacy/be ... asheet.pdf
available here...
http://www.fullcompass.com/product/351830.html
For somewhere under $300,000 US dollars, provides that added benefit of killing all weeds, ants cockroaches fungus,plants animals, children adults under 6 feet tall, TV's, appliances, fries all wiring within a 10 mile radius, sets up an EMP that will disable all air traffic, cars, trucks, motorcycles, and golf carts within a 1000 mile radius, and contaminate the soil so it can't grow anything for 400 years. All adults over 6 feet tall will be sterilized, and walk around dumbfounded sporting permanent \"Rock horns\" muttering \"DUDE that was AWESOME\"!
:shock:
I too, to remember his legacy, will have a two sale. $400, and if you know his beloved Austalian Shepherd's name, you'll get an additional 25% off.
So far not a lot of response from this forum, but the guys at PSW are lapping them up like Shlossy. ( :oops: crap!)
PS - I find the Belchfire a bit underpowered for my needs. I run all my cabs in series and the BF only puts out 96w at 512 ohms. What I need is the new Vurpfire amp. It actually increases output as the load decreases. (Something about the re-configured Flux-Capacitor) First full production run is April, so order now.
