Excess pink noise all the time
I've got a DriveRack PA that I'll hooked up in my new house after being in storage for a year.
After running through all the setup and diagnostics, I still get a lot of pink noise coming through: all channels, all frequecy ranges.
I've tried swapping amps and disconnecting components.
With only the DRPA hooked up and nothing else, the problem has been isolated. Hooking the amps directly to the preamp fixes it.
So it seems that the DriveRack is creating the issue.
Does anyone have suggestions on what I could do? Help is greatfully appreciated.
Olaf
Olaf
If the former, try a \"hard reset\" and see if the software just became corrupt...
Gary
Its a constant background hiss.
Sorry, how do you do a hard reset?
Still lots of hiss across the entire spectrum.
Tried:
- Playing with the gain at different cross over points
- swapped around a few amps
- disconnected all inputs
= no change.
Its definately coming from the DRPA
I noticed the same problem in a few other threads, but no solution, other than \"poor gain structures\"
I circumvented the PA and straight from the preamp, everything sounds great. I compared the outputs of the Preamp and the DRPA on my multi-meter, and they're very close. So I don't think the DRPA is providing excessive gains.
I'm no closer to a solution with this unit.
Olaf
Thats all I have to offer, try hitting the amps with a lower output from the DRPA (Crossover gain) and see what happens
Could be interpreted as pink noise
I've tried changing the gain, all the way up and down, but it doesn't make any difference at all. Just sounds like constant background noise.
Cabling was the first thing I played with. Disconnected everything except the DRPA and the amps, then messed with all the settings. Again its a constant hiss.
Some of the other posts suggest using the 480 model instead. Thats a large jump in price and I'm more likely to try the Behringer DCX2496. I'd loose the RTA, but I can work around that.
Make sure it's ALL the hi and mid outs...if it's not and just on one channel see if cable swaps on the outputs follow he noise, as Fanman said verify the cables, and try and see if there is a ground loop somewhere... You'll need to probably disconnect EVERYTHING from the DRPA connect up one known good cable ... probably to the quiet sub amp connect a horn to it's output and see if there is noise, if not try each cable on that known channel than follow with every amp and every amp channel then every output on the DRPA. Add cables/amps one at a time to see where the buzz comes in...if it's the DRPA send it in, but make sure you HAVE a problem with that and not a ground loop, or bad amp feeding back into the DRPA
After AutoEQ, the adjustments were all under -/+6 db.
Its on both channels.
I'm guessing the something is pooched and dropped it off at the local DBX rep for service. Hope they can do something with it. In all other respects, it has been a good unit.
The one thing I did notice, is that after running it for a while, the unit does get quite warm. I gave it more ventilation but the unit itself seems to be generating heat - seems a little strange to me
Mark
