QSC Amp settings
Recommended Driverack 260 settings for a system with
1 per side JBL MRX525 w/QSC 1602 - Bridged (per cabinet)
1 per side JBL MRX 528S w/QSC 3002 - Bridged (per cabinet)
Recommended crossover, compressor and limiter settings.
I understand the MRX cabs are in the wizard but the QSC amps are not. What would be the recommended amp attenuator settings, compressor and limiter settings for each amp. Thanks in advance. TP in NC
The 1804 settings were right on the money though....go figure...TP in NC
HOWEVER...You could have set the amp as specified and used the crossover gain control to set the amp to clip @ the 12:00 position... If noise was to become an issue you might want to compare the two methods and stick with what works best...
For stereo...
Click the config button.
Right click the (F)ilter for ouptut 5 and select 2x2 filter.
Press and hold \"CTRL\" and left click the module pairs then right click and select \"Link\".
Set up your filter with a high pass of 50-60hz @ BW18. This of course depends on relationship to the subs and use. You may have to raise the HPF to match the crossover of the mains and add significant delay to the Eons. Ahhhh, the 260. Ain't it great.
For a combined mono... there are several things that you can do to achieve the same results. See if you can figure them out.
if I want a full range singal to the Eons' can't I leave the high pass @ about 30 or is 50-60z low enough for the eon's for a full range singal??
1x1 filter, select the input as A+B then daisy chain the speakers, using out 5 only. It all depends on what & how you want to go.
