PA setup
Ok, I am doing the Gain Structure procedure and when using the Wizard to setup my Speakers and Amps it asks to \"adjust knob same as your amp\" which my High and Low amps are both set to 0 right now because that is the first instruction of the procedure. The Wizard has an adjustment on the screen showing 37%... what do I do here??
  • Totally ignore it... Set your gain structure and balance your system as outlined in this post.... You should configure your system before setting the gain structure...:D
  • I wouldn't \"totally ignore\" the recommendation, just \"mostly ignore\". For this reason... you should end up in the \"ball park\". If the wixard says 37% and you end up at 100%, chances are you've made a mistake somewhere. I've never quite understood the \"adjust the knob to your amp\" statement.
