Need help with my rig
Hi,
I just joined up after reading some of the troubles and admire the pro's that take the time to answer.
I bought the DRPA about 2 years ago. My partner has been using it. I've noticed he keep blowing the tweeter. This is what I have:
2 JBL 4731 RMX 850 running high (stereo), 2 RMX 1450 running mids (mono)
2 JBL 4719 2 CS800x (mono)
Allen and Heath GL2200
First, when I went one time to listen to the mix, the mids were really high. So high that if you walked next to the speaker it hurt your ears. I noticed on the DRPA, the output leds on the mids were not peaking, but the top yellow led was.
The band consist of trumpets, tuba drums and saxaphones. Can anyone help me tune this rig up?
Any help would be apreciated.
Raul
Raul
I would take a look at the GEQ for unnecessary boosts in the 7kHz-20kHz range... You may also try turning the amplifier attenuators down on the tops until you get a good balance between them and your subs... If that doesn't work you may need to lower the crossover gain for your tops...
Kev
Chances are also that he has Auto-EQ'd the room and gone with it as is.
Also do as Dra and Kevin suggest, I would also look at the possibility that he added a \"constant directivity horn eq\" to the horns on the speakers...(I believe those have one.. but if the level is too high on that shelf filter.. it could cause the diaphragms to fry) This and more are all addressed in the Welcome READ ME FIRST section. In the \"Links\" section you will find the Peavey \"Tech Notes\" there you will find the explanation of CD horn EQ by the principal inventor, Marty McCann who worked for EV at the time.
I could give you the link but I would prefer you did the homework and you will then see that there is a lot of good info in those links and you will hopefully READ them and learn what your up against.. I recommend HIGHLY that you read the :
Top 10 Ways To \"TOAST\" Speakers and Diaphragms
BOUNDARY CANCELLATION
How to eliminate low frequency noise cancellation with proper woofer placement
Shock Hazard and Grounding
That should give you something to get started with...
Raul
