Am I correct in thinking that the DRPA does not allow me to save AFS settings before powering down the unit? Meaning that I will face a reset of the AFS everytime I power up and increase the master fade? thanks.
If you STORE the set-up before you power down, it will be there when you power up, for sure. I am uncertain if it stays without the pre-shut down STORE. You could do a test and see for sure .
