crossover advice
I again want to thank everyone for advice on my prior post. I would really appreciate some additional advice re: setting up best optimized crossover choices.
The speakers are custom and consist of the following drivers-all TAD products
HF-compression driver with 100mm Beryllium diaphragm/ sectoral horn
this driver is speced at 600-20000 Hz
MF- 12\" polymer graphite driver freq response 200-3000 Hz
LF- pair of 16\" drivers- polymer graphite freq response 28-2000 Hz
any recommendations as to the crossover points to best utilize the drivers. the HF driver is phenomenal not to discount the performance of the low and mid range- so do I favor this driver in the crossover? Likewise is there a \"sweet spot\" for the 12\" mid
Again thanks for any suggestions
Ludwig
Ludwig
The only info being the subjective comments of \"incredibly flat response\" etc. The response curve of the TAD reference one using these drivers is extraordinarily flat and linear. TAD drivers are generally used in studio monitoring applications with commercial 2 way and 3 way systems in the $60000/ pair range. so much for subjective.
The data I do have is-
HF driver recommended crossover 600Hz or greater with 12-18 dB cutoff
this driver is commonly used without the midrange in a 2 way system with the 16\"
MF driver \"flat\" from 200-3000 Hz recommended crossover the same
the free air resonance is at 52 Hz Qms-1.43 Qes .15
LF driver \"flat\" from 21-2000 Hz recommended crossover 900
the question is where the best utilization of the mid would be to allow the best usage of the truly remarkable HF driver to be best represented
with a given cutoff how much overlap in the transition?
many thanks
Ludwig
The 16\" references the 900hz point and since used with the HF driver sounds like they cross at 900hz when together. Now go from there and divide up the mid with the 12\". Try 200hz to 1800hz. That is about 2 octives below the 900hz and 1 octive above.
16's covering 25hz (if that low, I'd higher) - 200hz which is 3 octives.
12 covering 200hz - 1800hz which is 3+ octives.
HF driver covering 1800hz - 20K which is 3+ octives.
All filters - LR24
Ludwig
