Peavey SP1x and Peavey SP118x
Previously I posted questions..but didnt realize I had the Peavey SP1X and 118x speakers.
I need the crossover settings for these speakers. If possible I need it in simple terms.
Low---Low pass
Low---High Pass
Mid---Low Pass
Mid--High Pass
High---High pass
I have a Driverack PA set for sterio 3 way I have My Highs and mids for the right side coming from 1 crown CE1000 same for the left side from another crown CE1000
My lows are coming from a crown CE2000
I understand that my low end is kinda underpowered.
I am sooo close to having this system sounding great. I think the difference lies in the tunings for the crossover. I am yet to set that fully.
SP1X SPECS
SPECIFICATIONS
Frequency response, 1 meter onaxis,
swept-sine in anechoic
environment:
56 Hz to 19 kHz (±3 dB)
Usable low frequency limit
(-10 dB point):
42 Hz
Power handling:
Full Range:
700 W continuous
1,400 W program
2,800 W peak
Low Frequency Section:
500 W continuous
1,000 W program
2,000 W peak
High Frequency Section:
80 W continuous
160 W program
320 W peak
Sound pressure level, 1 Watt,
1-meter in anechoic environment:
Full Range:
99.0 dB SPL, (2.83 V input)
100.0 dB SPL, (2.83 V input)
110.0 dB SPL, (2.83 V input)
Maximum sound pressure level
(1 meter):
Full Range:
127 dB SPL continuous
133 dB SPL peak
133 dB SPL peak
129 dB SPL continuous
135 dB SPL peak
Radiation angle measured at -6 dB
point of polar response:
80o horizontal by 40o vertical
Transducer complement:
1x 15 in. woofer, vented
1508-8 HE BWX
1x 1.6 in. exit/100 mm voice coil
compression driver on CD horn
44XT (w/o adapter) on a CH7 constant
directivity horn
Box tuning frequency:
50 Hz
Crossover frequency (internal
passive):
Low Frequency - High Frequency:
1,400 Hz
Recommended active crossover
frequency region and slope:
1600 Hz at 12 dB/octave, plus CD
horn EQ
Time offset:
Low Frequency:
Delay 0.67 ms
High Frequency:
0.00 ms
Impedance (Z):
Full Range:
Nominal: 8.0 Ω
Minimum: 6.4 Ω
Low Frequency:
Nominal: 8.0 Ω
Minimum: 6.9 Ω
High Frequency:
Nominal: 8.0 Ω
Minimum: 7.1 Ω
Input connections:
2x 1/4 in. phone jack and 1x Neutrik®
NL4 Speakon® (bi-amp only)
Enclosure materials and finish:
3/4\" OSB finished in black carpet
SP118X SPECS
SPECIFICATIONS
environment:
50 Hz - 300 Hz (±3 dB)
(-10 dB point):
31 dB
Power handling:
Sub Bass Section:
500 W continuous
1,000 W program
2,000 W peak
1 meter in anechoic environment:
Sub Bass Section:
98.0 dB SPL, (2.83 V input)
(1 meter):
Sub Bass Section:
125.0 dB SPL continuous
131.0 dB SPL peak
Sub Bass Section:
1 x 18\" woofer, vented
1808-8sps BW
Sub Bass Section: 39 Hz
Harmonic Distortion:
1% rated power
2nd Harmonic:
100 Hz: 0.37%
1 kHz: 0.46%
3rd Harmonic:
100 Hz: 0.23%
1 kHz: 0.59%
10% rated power
2nd Harmonic:
100 Hz: 0.82%
1 kHz: 1.68%
3rd Harmonic:
100 Hz: 0.53%
1 kHz: 0.74%
Impedance (Z):
Sub Bass:
Nominal: 8.0 Ω
Minimum: 7.5 Ω
Input connections:
2 x 1/4\" jack
3/4\" OSB and MDF finished in carpet
Dimensions (H x W x D):
Front:
32.50 in. x 20.75 in. x 29.97 in.
826 mm x 527 mm x 761 mm
Rear:
Net weight:
122 lbs. (55.4 kg)
Features
This loudspeaker system delivers high
output, low distortion bass from a single
18\" BWX woofer mounted in a vented
enclosure. It is designed for portability and
includes handles, metal grille, reinforcing
corners, durable carpet finish and rubber
feet. A pole mount is included for
mounting of a high-pass enclosure.
Description
The SP 118X is an add-on subwoofer
designed to make it easy to add more low
end to the SP X Series or other full-range
speaker systems. Other uses include bass
guitar and drum monitoring.
The enclosure is constructed of 3/4\" high
density OSB and MDF, and covered with a
heavy-duty black carpet and reinforced
with polymer corners. A black metal grille
covers the front of the enclosure.
Recessed handles on either side provide
portability.
This low frequency enclosure is comprised
of an 18\" BWX Black Widow® woofer with
Kevlar® impregnated cone, mounted in a
vented enclosure. This design provides
strong bass extension and high power
handling to complement a full-range
sound system.
Low---Low pass
Low---High Pass
Mid---Low Pass
Mid--High Pass
High---High pass
SP1X SPECS
SPECIFICATIONS
environment:
(-10 dB point):
42 Hz
Power handling:
Full Range:
700 W continuous
1,400 W program
2,800 W peak
500 W continuous
1,000 W program
2,000 W peak
80 W continuous
160 W program
320 W peak
Full Range:
(1 meter):
Full Range:
133 dB SPL peak
133 dB SPL peak
135 dB SPL peak
1508-8 HE BWX
directivity horn
50 Hz
passive):
1,400 Hz
horn EQ
Time offset:
Low Frequency:
Delay 0.67 ms
High Frequency:
0.00 ms
Impedance (Z):
Full Range:
Nominal: 8.0 Ω
Minimum: 6.4 Ω
Low Frequency:
Nominal: 8.0 Ω
Minimum: 6.9 Ω
High Frequency:
Nominal: 8.0 Ω
Minimum: 7.1 Ω
Input connections:
SP118X SPECS
SPECIFICATIONS
environment:
(-10 dB point):
31 dB
Power handling:
Sub Bass Section:
500 W continuous
1,000 W program
2,000 W peak
Sub Bass Section:
(1 meter):
Sub Bass Section:
131.0 dB SPL peak
Sub Bass Section:
1808-8sps BW
1% rated power
2nd Harmonic:
100 Hz: 0.37%
1 kHz: 0.46%
3rd Harmonic:
100 Hz: 0.23%
1 kHz: 0.59%
10% rated power
2nd Harmonic:
100 Hz: 0.82%
1 kHz: 1.68%
3rd Harmonic:
100 Hz: 0.53%
1 kHz: 0.74%
Impedance (Z):
Sub Bass:
Nominal: 8.0 Ω
Minimum: 7.5 Ω
Input connections:
2 x 1/4\" jack
Front:
Rear:
Net weight:
122 lbs. (55.4 kg)
Features
Description
portability.
sound system.
The subs are -10db at 50hz naturally. So something like...
50hz BW 18 to 90 - 100hz LR 24, then match (or very small gap) the 15\" mid's high pass to the above from Peavey. You'll have to find the amount of sub delay (probably max) yourself by playing. Don't forget that you'll need to attenuate the horn side of the amp or the high x-over gain, or the horns will cut your head off.
Keep us posted.
PS - An RTA mic will really help. Set a 1 stack out side and use the auto EQ and PEQs to set up system.
OR does it matter?
BTW the HF crossover point is 16 k or up and with your limited power I'd consider an even higher sub/mid xover maybe as high as 110/120hz.
Regards
Moderator 8)
I think you guys love \"knowing it all\"...lol
I really appreciate your help
In the DRPA when setting the crossover I should have a setting first for the HIGH PASS for the Lows...Next the LOW PASS for the Lows.
I then have one for the HIGH PASS for the mids and LOW PASS for the mids. Finally I should have a setting for the HIGH PASS for the highs.
From what I have so far I am looking like this:
LOWS - HPF = 50Hz BW 18 ??db
LOWS - LPF = 110/120Hz LR24
MIDS - HPF = 1600Hz ?? 12db
MIDS - LPF = ??Hz ??
HIGHS- HPF = ??? Hz ?? ??db
Do you see now where I am getting stuck? Please excuse my ignorance
I am learning.
LOWS - LPF = 110Hz LR 24
(18\" subs do 50 to 110)
MIDS - HPF = 110Hz LR 24
MIDS - LPF = 1600Hz LR 12 (or LR 24) try both
(15\" mids do 110 to 1600)
HIGHS- HPF = 1600Hz LR 12 (or LR 24) try both
HIGHS- LPF = NA
(2\" horns do 1600 to \"out\")
Clearer?
Been following... even did a post which...?hmmm... Nice work Dra... As for the Horns.. they are 1 \" throat and I wouldn't go ANY lower than 1600 hz...as the titanium diaphragms will prematurely self destruct... I recommend 1800-2000( the woofers go to well over 4000 hz so no worries..) for longevity sake. I have used the same diaphragms for over 8 years in the high output disco/karaoke format and have had no failures, as well as a number of monitors which must do vocal AND music duty for karaoke use in a high volume pro audio setup.
I also recommend you try both, but I believe you will see that less \"interaction\" will occure at crossover point with a 24 DB/octave filter, which will translate to better intelligibility at the crossover point .
Be well
Now..One more question has come up within my band....
I know that I can turn the GEQ off in the DRPA...I know by reading some of the other posts that I can use an outboard EQ to make quick adjustments on the fly. Would I connect this outboard EQ just before the DRPA in order to keep the \"FLOW\" of signal the same as the DRPA diagram shows?
Depending on HOW ON THE FLY you mean, consider leaving the DRPA EQ on, make the adjustment, copy to the DRPA EQ then take the outboard back to -0-. The DRPA EQ will be cleaner to the over all tone.
Or does it matter sense the sub out will be unpluged anyway ?
Also I missed that this is a 44xt... which is a 2\" exit and could easily be crossed @ 1400 hz...
