little help
i am very happy to say that i just purchase a driverack pa for my rig and i am anxiously waiting to use it as soon as i receive the new cables and rta mic for it which it will be in sometimes this week. now back to my situation at hand. i have a crown c1000 at the moment i will get a crown xtl2000 very soon. i also have a pair of peaveys 215s. my question is can i make the highs, mids, & lows work with the drpa without any additional amps or speakers and if so how do i go about it. i did read the manual its very informative and i did see the presets for the amps & speakers that i have so i am thinking it could. i just want to ask the pros(current users before i get ready to fire this puppy up. i will appreciate the info and thanks in advance. you can send me a pm if so.
Make sure you list all the speakers and amps that you intend to use and how you intend to use (configure) them.
here are the specs:
they are PV215s
Frequency range (-10 dB, half space):
40 Hz to 21 kHz
Frequency response (± 3 dB, half
space):
58 Hz to 17 kHz
Sensitivity (1w/1m):
98 dB
Power rating (program):
700 Watts
Peak power capacity (peak):
1400 Watts
Maximum SPL:
123.5 dB
Transducer complement:
Dual Peavey heavy duty 15"
premium woofers, RX141.4" titanium
diaphragm dynamic compression
driver on a 60˚ x 40˚ coverage
constant directivity horn
Driver protection:
Positive temperature coefficient
resistor
Nominal coverage pattern:
60˚ x 40˚
Electro-acoustic crossover frequency:
2.6 kHz
Nominal impedance:
4 Ohms
Input connections:
Two 1/4" phone jacks in parallel
Enclosure materials & finish:
Trapezoidal, black carpet-covered
enclosure with dado-joined 1/2"
MDF (Medium Density Fiberboard)
and a full-length, black powdercoated
steel grille
Dimensions (H x W x D):
Front:
48.25" x 18.38" x 14.25"
122.6 cm x 46.7 cm x 36.2 cm
Rear:
48.25" x 11.75" x 14.25"
122.6 cm x 29.8 cm x 36.2 cm
Weight:
79 lbs. (35.9 kg)
Mounting or suspension:
Die-cast aluminum 1-3/8" polemount
cup for stand mounting
and like i said they are listed in the presets of the drpa and so is my amp i do have a crown c1000 and i will be purchasing an xtl2000
Do a gain structure and limiter setting as detailed in the FAQ > Welcome post.
i'm sorry about the confusion. what i really want to know is how to set them up. as far as the high mid lows thats just the plug ins that i see on the drive rack. i've read about the set-ups and saw the aplications but none looked like mine. will mine work without any additional speakers or amps. and how do i set them up.
buy the way what is bw18?
Press the wizard button.
Select stereo linked GEQ.
Select your speakers from the list.
Select your amp from the list.
Load the congig by pressing the scroll knob. It will say 2 x 2 .
That means two (stereo) inputs and two (stereo) ouputs.
Press x-over and set the Hi-pass (lo-cut) filter to 50hz (45 at the lowest).
Select the filter type (LR , BW, or BS). BW (Butterworth) is recommended here.
Each type will also have slope numbers (6, 12, 18, 24). 18 is recommended here.
Simply scroll through and select BW 18.
You should now save your set-up. Name it and then press save (3 presses required).
You will connect to the Hi outputs.
PS - Until you have read up on the pit falls of the auto-EQ, don't use it. Unless you use it correctly your sound will NOT be good.
man your awesome i like it how you put it together i actualy understood that until you got to the ps. what do you mean by pit falls of the auto eq?
does this mean i would have to eq manually? is this information on the users manual? please tell me more. ireally apreciate your help DRA.
He did not include, but has stated in the past that indoor auto-EQ is useful for the frequencies between about 160 and 700 (that ain't a lot). The rest by ear. The post will explain why that is.
http://www.driverack.com/drug/view_thre ... d_id=41581
http://www.driverack.com/drug/view_thre ... d_id=41419
Mike Kovach and I Wrote the paper a couple years ago. As Dra said read the FAQ and see if some of what your experiencing isn't covered there. make sure you read ALL the FAQ's as there is a LOT of help there...
ok gadget i will do that. i just got my cabling and the rta mic today so now i will hook it up and see where we go from here. if by any chance i should run into trouble or a question can i pm you or dra?
Gary
gadget in the faq area does evrything you wrote as far as auto eq and others apply to mobile djs as well?
on initial start up i did the preset set-up, i found my speakers pv215s, i found my amp ce1000 (Until I get new One In two Weeks). the dbx asked dual mono or dual stero, i choose dual stero, the dbx asked for subs i and no, the dbx asked me about the voltage sensitivity of my amp i verified and confirmed, the dbx told me to set the level w/data well to match amp(I set to 50%). when i went to save my program the dbx wanted to save it to factory is what it looked like to me. how do you rename and save to user presets? now i did do that x-over but am a little unsure. do i just press x-over once or what i believe i did it wrong i will double check and get back with you.
Pick a preset (program #) THEN go into the wixard. When done, name it (press Store and use the data wheel) and save it (press Store 2x)). Just press the buttons that it tells you to.
It sounds as though you abandoned the gain structure set-up for the wizard recommendation. IF you go this route (and I'm not recommending that you do), you should set the amps knobs to the possition indicated on the DRPA screen.
Also, you will find for your application that setting the EQ to Stereo - Linked will be far easier to deal with than Dual Stereo.
no dra as a matter of fact i am just starting to get the gain structure together as i am emailing you.
as far as dual or link the drpa only offered me dual mono or stereo link thats it unless i missed something.
on the set up wizard everything is as asked for except that when i did the x-over you had a choice of H M or L and H was highlighted. i did bring it to 50 hz and BW 18 now there is still the 0.0db in that same menu. do i do anything with it? i get back to you guys
ok dra i've somewhat done the gain structure and the limiters according to the instructions. what next or what else can i do to get the best results? what do i do with the geq or the peq. i also do karaoke what can i do to make it awesome. how do i set the limiters and compressors for the mics?
As far as I can tell you are only using Peavey 215's.. no subs. To this end I must say you will never get awesome sound...with those speakers. Good sound, yes, if you really know your stuff... But with 1\" exit horns and Black widow woofers you will never get that exceptional low end, and your top end will be only as good as your tuning skills.
Dra has tried to understand your requests but you haven't given him the info he needs to help you either... We expect a certain commitment here, you need to do your homework. We have provided the information, arranged it so that it's accessible, and succinct. You must however do the work to actually read and comprehend the information so you can understand the information/settings that we are providing. Otherwise we are just spinning our wheels here. This is a product with a steep learning curve, and a necessary commitment to the technology, and learning it's parameters in order to be able to understand what we are specifying and what to do with the information. To date you have not been able to elicit what you need to know, or unable to implement the settings we have provided.
Please go back and read the FAQ's and the links provided and come back with cogent questions with specific information about your system and what you are attempting to accomplish, or where you are having problems...
Respectfully
well than i guess i did set it up right because i have raised the volume levels on my amps where they have not gone before. it it sounds pretty dam good compared to without the drive rack. all i had was a cheesy mixer a want to be sound board, my ce1000 and my peavys. i am waiting for my xti2000 to arrive and beleive you me it will sound even louder because my ce1000 is only 400watts per ch and after the driverack settings and the gain structure it was kicking with no clipping. i do appreciate everything that you and dra have done to help me fully understand the drpa. i am pretty sure that when i upgrade my speakers and add a sub i will the other available channels. your teachings and literature were not in vain. audio & video is my hobby. i will keep working and tweaking and perfecting my abilitys so you guys were not spinning your wheels. i thank yall for your patience. overall the setting up the drpa prove to be a little challenging and very interesting. don't loose hope i can do this!
You asked about setting the compressors for the mics. Well, you've fallen into a trap. Many believe that Driveracks will replace \"a rack full of gear\" that are intended for individual channel use, such as compressors. The Driveracks do replace a rack full of gear that are whole system. If you set the compressor to compress the vocal mic, when the mic needs compression everything else will compress with it and likely everything else will cause the compressor to kick in first, then also pull down the mic.
Whole system compression for what you do is not recommended. An exception for use would be if you were running sound for a lecturer that tended to scream on occasion.
For the PEQ's search Auto EQ and PEQ for some tips on \"flattening\" your speakers outdoors. These tips may be in the top section somewhere. Read all of the posts there.
Start with the Music-Hi (very narrow notch) and set 6-8 fixed. Then change the lives to a wider notch (they grab faster) with a short release time. Play around with different scenarios and see what works for you. Lots of posts as well. Search AFS or feedback.
ok i will do that thanks
