DRPA 1 - Gain Structure
Like many I am having trouble using the DRPA to its full ability. I can manage to get a decent sound out of it but am unsure of many aspects, and think that I am probably not using it too its full potential. Rather than just ask for over-all help and giving you my setup and asking for directions, I thought I'd just tackle one issue at a time, and hopefully get answers in reletaivly laymen terms to help both myself and others who may come to this forum.
Current situation:
The set-up im currenty applying the DRPA to (don’t laugh…its just for home practice so yeah, cheap and nasty) is a small alto speaker and 2 x behringer B215A powered speakers. No sub. The music is acoustic only, one guitar, one vocal.
Behringer B215A powered speakers frequency range = 55Hz - 20kHz
Gain Structure:
Ok my first question is about gain structure. I have read a lot about how to set up a system, however it mostly applies to those with separate amps and speakers. To start me off, could I just get a quick overview for the gain set-up for if your running powered speakers. (I know it shouldn't be hard, but again, I just want to make sure)
Current situation:
Gain Structure:
If you intend to use the three speakers set up a custom 2x3. Use the Hi outs to the BEH speakers and send the left lo out to the Alto speaker. Select the XOVER section and set up a bandpass for the BEH speakers this can be accomplished by simply setting the HPF to 40 hz or so for the hi outs.
Do the same for the alto's .. I have no info to work with for those speakers...
Gadget has an excellent idea, that way you have some volume control in the x-over section and PEQ (3 hi, 2 lo) for the 2 sub-systems (not sub woofer).
PS - 1 question at a time is a good way to get \"more\" help with each topic.
Have you read the \"welcome\" post in the FAQ section?
Have you downloaded the 260 Driveware GUI?
but thanks for the info
1 - Power everything on in proper order
2 - Turn the speakers down
2 - Disable all of the DRPA’s
3 - Set the mixer main input fader to unity (0db)
4 - Play pink noise through the mixer with channel input fader and overall main input faders at unity (0db)
5 - Turn up speakers until they clip then bring back.
One question I have is the +4/-10 switch, which setting is this meant to be on?
I also don’t understand what the ground lift switch does, should this be in or out.
Again thanks for all the advice.
Couple of things...
Set channel input fader to -0-, set main output fader to -0-, THEN, turn the channel input gain knob up until mains meters are -0-.
This next one kind of depends on how well your limiters limit. Set the mains to bumping RED on the meters, THEN turn up you speaker to a hard (mostly on) limit. This mostly depends on if you want to cruise (no limiting) at -0- and only want limiting above and into the red. Lots of personal preference here.
+4/-10 Look in your mixer manual. It will tell you on the SPEC page what it's output is. It is probably +4. What ever it is, match the DRPA to it. If you mismatch them, you may gain or lose \"gain\" and gain or lose \"noise\".
Ground lift - used if you have a bad hum, usally from running power from different sources (circuits). And no, it won't always help.
naildow
hacklemar
obviouslyal
thievesal
