New amp (s) and sub (s)
Thanks to everyone for the helpful posts.
Especially Cram Gadget and DRA.
I have a mackie mixer- DRPA-Crown 402 (for the tops) Crown CE2000 for the bottoms of TR1503 Carvin 3 way (biampable) speakers and want to get some subs and amps to match. I am looking at the Crown xls or maybe the QSC (plx) versions and either EV, Carvin TRX 18\" sub or maybe the Tapco 6918. The rear plate of the Carvin 1503
http://www.carvin.com/manuals.html has a hidden switch that I need to access but then I think I can get subs and triamp. I have binks cd and RTA mic just need advice on consumer subs and amps.
Just looking for feedback (pun intended) on a good choice in cheap (not behringer thanks) amps and subs :oops:
Give a budget.
Is it your intention to stack each top on a sub? Because one option is a single, better, more powerful sub vs two \"cheapies\", but then the stack option is out
Is Ebay an option for you, given the right situation?
gadget
The key to homemade cabs is how the lighting is when they will be seen.
Those Tuba 24's will outperform subs 10 times their cost... Go lower get louder and be cleaner...
Lets face it. the cheap stuff you can buy today isn't worth your time or money...A front loaded sub needs to have a 4\" voice coil and a very good design in order to be worth a damn...I have some of the Carvin stuff and they rate it's power handling about double what it can actually handle...Their pro stuff is ok but their semi pro stuff is only fair.
Yorkville makes a decent under $1000 sub, The QW stuff by Peavey is good...I avoid BW subs they just can't get down with it...
My $.02
Looking hard at the t24's--If i build one, i might as well build 4, since theyre small.
First i have to decide on which tops to build. Mainly looking for small, light, and LOUD!!!!
DR's are the hardest to build, but seem to be the best. I was thinking DR200's. That way my ol lady can still do her own setups/teardowns.....
Shes a KJ/DJ
http://www.partsexpress.com/webpage.cfm ... oup_ID=583
I was looking at the sigma or omega. Which do you recommend for the BillFitzmaurice design cabs ??
http://www.carvin.com/products/single.p ... 8&CID=RSPK :oops: What plywood are you using ? 13 birch ply or would it work with less. and would it hurt to double the thickness of the front of the cab that holds the driver ?
That Carvin driver is an Eminence omega 18...
gadget
Hello, I have eight of Bill's DR200's w/ Beta 8 drivers and these speakers rock. I am also building four Titan 48 right now and I know that they will sound like a wall of bass coming at you!!! Bill's speakers will put any pro speakers to shame, so build some of them if you can. You also only need 1/2\" B.B. plywood for his speakers. save your back and use the 1/2\".
Cheers,
DJ Scotty G
