i got a drpa and am confused..
hello i just bought a drpa and not sure what the hell im doin.. here is what i have..
(2) B-52 mx1515
(1) 15\" kappa pro 15lf in avatar box
crown xls 602
carvin dcm1000
trying to figure out how to set up this rig.. if anyone has any ideas for me that would be great... also should i get that RTA-M Mic.. would it help.. should i spend the cash to get it..
here are the specs for the speakers and powers...
B-52 MX1515
SPECIFICATIONS
Nominal Impedance: 4 ohms
Frequency Response: 40-19k hz
High-Freq. Dispersion: 90 x 40
X-Over Points: 1.6k hz
Power Handling: 600 watts
SPL @ 1w1m: 99 db
Peak SPL: 130 db
Dimensions (W�x H� x D�): 19x45x18
Weight (lbs): 98 lbs
Avatar Cab with Eminence Kappa Pro LF 15
SPECIFICATION
Nominal Basket Diameter 15\", 381mm
Nominal Impedance* 8 ohms
Power Rating watts 600W
Music Program 1200W
Resonance 35Hz
Usable Frequency Range 38Hz-1.8kHz
Sensitivity*** 97.8
Magnet Weight 120 oz.
Gap Height 0.375\", 9.53mm
Voice Coil Diameter 3\", 76.2mm
THIELE & SMALL PARAMETERS
Resonant Frequency (fs) 35Hz
DC Resistance (Re) 6.5
Coil Inductance (Le) 1.40mH
Mechanical Q (Qms) 7.3
Electromagnetic Q (Qes) 0.32
Total Q (Qts) .30
Compliance Equivalent Volume (Vas) 198.8 liters / 7.0 cu. ft.
Peak Diaphragm Displacement Volume (Vd) 507cc
Mechanical Compliance of Suspension (Cms) 0.20mm/N
BL Product (BL) 21.6 T-M
Diaphram Mass inc. Airload (Mms) 102 grams
Efficiency Bandwidth Product (EBP) 112
Maximum Linear Excursion (Xmax) 6.7mm
Surface Area of Cone (Sd) 856.3cm2
Maximum Mechanical Limit (Xlim) 18.0mm
Crown XLS 602
XLS 602 Specifications: 2-ohm Stereo (per channel) 840W
4-ohm Stereo (per channel) 600W
8-ohm Stereo (per channel) 370W
8-ohm Bridge-Mono 1,200W
4-ohm Bridge-Mono 1,680W
Performance Sensitivity (volts RMS) for full rated power at 4 ohms,
XLS-202 0.725
XLS-402 1.025
XLS-602 1.26.
Frequency Response (at 1 watt) 20 Hz to 20 kHz 0.75 dB.
Phase Response (degrees at 1 watt)
at 10 Hz 10.
at 20 kHz +19.
Signal-to-Noise Ratio (20 Hz to 20 kHz)
A-weighted, below rated power > 100 dB.
No weighting, below rated power > 95 dB.
Total Harmonic Distortion (THD) at full bandwidth power, from 20 Hz to 1 kHz < 0.5%.
Intermodulation Distortion (IMD) (60 Hz and 7 kHz at 4:1) from full rated output to 40 dB < 0.3%.
Damping Factor (8 ohm) 10 Hz to 400 Hz >200.
Crosstalk (below rated power)
at 1 kHz 82 dB.
at 20 kHz 58 dB.
Voltage Gain (at maximum output) 31 dB.
Carvin DCM1000
HT POWER AMP SPECIFICATIONS:
MODEL DCM1000
Bridged RMS Continuous
4½, (20-20k Hz, <1.0%) 1000w
8½, (20-20k Hz, <1.0%) 700w
Both Channels RMS Continuous
2½ (20-20k Hz, <1.0%) 500/500w
4½ (20-20k Hz, <1.0%) 350/350w
8½ (20-20k Hz, <1.0%) 225/225w
THD (Typical—1/2 power): 0.03%
Damping Factor: >400
Slew Rate: bridged mode >45v/µs
Sensitivity: (4½, Vms) 1.0 V
Signal to Noise Ratio: Above 100dB
Frequency Response: 20 Hz to 20kHz
(10 Hz & 40 kHz)
Input Impedance: >20K ½, balanced
(2) B-52 mx1515
crown xls 602
carvin dcm1000
B-52 MX1515
SPECIFICATIONS
SPL @ 1w1m: 99 db
Peak SPL: 130 db
SPECIFICATION
Music Program 1200W
Resonance 35Hz
Sensitivity*** 97.8
Total Q (Qts) .30
Crown XLS 602
XLS-202 0.725
XLS-402 1.025
XLS-602 1.26.
at 10 Hz 10.
at 20 kHz +19.
at 1 kHz 82 dB.
at 20 kHz 58 dB.
Carvin DCM1000
MODEL DCM1000
(10 Hz & 40 kHz)
I used the DR260 DriveWare Wizard to configure a custom starting point... I recommend that you click here and download the DriveWare GUI... Play around with the DriveWare and get yourself familiar with it... These settings should work...but you will need to key them manually with the DRPA... I would read the DRPA manual but it's assumed that the user has prior experience with PA systems... Mr. Dra recommends sitting at the kitchen table, poking around, and getting familiar with the menus and screens… You may also want to look at the \"Training Modules\"... The tab is located at the top right of this screen... I also recommend that you read Gadget's \"Welcome\" post in the FAQs category and setup your gain structure...
It's not going to sound “great� until you setup your gain structure, delay timing, and perform an Auto-EQ (for inside use only) with the RTA mic... When you do the Auto-EQ only enable one side (mute the other) and use the fast mode... Once it has completed set everything (in the GEQ) from 0-100Hz flat (at 0dB) and adjust everything from 7KHz and above to suite your taste...
Most of your questions have probably already been asked so I would lurk around the Forum and do some research... You may also want to read this thread because there is lots of good information scattered through out...
2X3 using Crown and B52s (L/R stereo) for tops, and Carvin (bridge-mode) with avatar for summed mono sub...
If Dra or Gadget chimes-in I highly recommend that you follow their suggestions!...:)
Cheers,
Kevin
the b-52's are pretty good... sound great to me.. just not enough bass from sub.. and its a damn good sub but two would better? im all worried of fryin something.. but thanks. any other ideas would be great..
p.s. what do you thing of the bbe 482i sonic maximizer... ya or na..
2 subs better than 1. 4 subs better than 2.
If you add sub(s), then you can jump into the true realm of the x-over. Your tops will clean up dramatically. Then I would say a x-over point in the range of 100hz.
Once you get to the point of finalizing your system, post pack and we'll go from there.
Sorry Dra,...I couldn't help myself... I've been waiting to recommend this "gadget" for a long time...
Cheers,
Kevin
Hate is such a strong word :? Perhaps I could mitigate that a bit with this statement.. \"On an individual channel/instrument... and used as an effect they can be kinda fun \"but as a whole system processor they only take something that sounds like crap and \"psycho-acoustically\" tricks your ears into believing something that isn't there ..is. You set up the Driverack right and you won't need or want smoke and mirrors...it will sound MUCH better without that \"stuff\"
