Equalizer
Why would someone insert an EQ in the system when there's a digital EQ in DRPA
  • IF... you had the system tuned the way you wanted and had visiting \"board engineers\" they could then be allowed to \"tweek\" the system to their hearts content and a simple \"flick of the switch would revert back to house normal...
    IF your system was running HOT and you were having \"issues\" with the house sound and quick tweeks were needed...
    IF you put the DRPA in the amp rack and it's hard to get to it quickly..
    IF you have the \"senior vision\" as I do and navigating the menu's in the dark and in the heat of battle...
    However, I don't like the idea of interrupting a pristine audio chain and inserting an EQ...
  • One more option, may or may not apply, is if you need to tailor an input. Kick, snare, vocal, etc for crappy mic, instr, or voice.
