Home dbx Forum dbx Forum Archive General Announcements
New DriveRack 260 Software
edited April 2007 in Announcements
We are pleased to announce that new firmware has been released for the DriveRack 260, with an accompanying new version of the DriveWare GUI.
DriveRack 260 Changes from Firmware V1.020 to V1.510:
1. New speakers supported in the Setup Wizard:
• JBL SRX700 Series, JBL JRX100 Series, JBL MRX500 Series, PRX500 Series, JBL VRX900 Series
• Mackie SRM 450 and SRM 350
• Peavey PR Series, Peavey PV Series
• Yamaha BR Series, Yamaha Club-V Series
2. New amplifiers supported in the Setup Wizard:
• New Crown XLS series, Crown Xs series, Crown XTi series, Crown CDi series, Crown DSi series, Crown I-Tech series
• Peavey PV series
• QSC RMX series, QSC PLX series, Yamaha P series
3. In the Setup Wizard, for AM4200/6200 Passive mains with AM4115/4125/6115/6125 Lows and AE subs, the Low amp gain is used as the reference gain instead of the sub amp gain which was previously being used in error.
4. Corrected amp data for Crown PT series and K1 amplifiers.
5. GEQ filters in the DSP were changed to double precision. This fixed a bug reported by a user where temporarily shorting the inputs would cause some spikes in the noise floor.
6. PEQ Shelf filters were not accurate for gains between -5.5 dB and -0.5 dB. This has been corrected.
Firmware Update Notes:
A. If updating from V1.000 to V1.5000, all user programs will be lost. Customer’s should be advised to save programs using DriveWare. After updating to version V1.500, user programs can be reloaded using DriveWare. This condition does NOT apply if updating to V1.500 from any version later that V1.000, i.e. V1.010, V1.020, or V1.050.
B. The only change between V1.500 and V1.510 is item #3 above.
New features in DriveWare V2.6.1:
1. New speakers supported in the 260 Setup Wizard:
2. New amplifiers supported in the 260 Setup Wizard:
• Peavey PV series
To download the new GUI go to the dbxpro downloads page:
http://www.dbxpro.com/Download/index.htm
and click on the V2.6.1 link under Software
To download the new Firmware go to the dbxpro download page:
and click on the V1.510 pulldown under Firmware.
If you use the DriveRack 260, it is recommended that you download both the GUI, and update the Firmware in your unit(s).
Thank you,
Dale Sandberg
Senior Product Manager
dbx Professional Products
