Connecting my new DBX Driverack PA
Ok, I am a little intimidated. I just got my DBX Driverack P.A. I am somewhat of a novice at this and would like some help connecting this sucker. I am using this for a live band and I need to hook up one sub (mono) two double 15 inch cabs(Stereo), two single 15 inch cabs(Stereo), and stage wedge/floor monitors (mono.)
I noticed there are six XLR outs, and I really only need five because of the two mono singals (Sub and Monitors) My question is, can I use this as a 2X5 and run the monitors and sub off the left/right low?
I am really afraid of blowing something up
How should I hook up all my speakers?
Thanks very much for your help!
Dan
Dan
As far as the other connections, am I correct in taking the right and left out of the board, into the R/L input on the DBX, then the stereo outs on the highs and mids, and a mono out for the subs?
Dan
You'll need to set up a 2 x 3 or a 2 x 5. It depends on what you intend to do with your 2 sets of different top cabs. For example, using the dual 15's as mains and the singles as outer or inner fills.
Regardless, I would suggest setting a 2 x 5. This will allow you to set limiters / delays / PEQ's / and output level for each set of speakers. Hi L & R to the duals , Mid L & R to the singles, and lo / mono to the sub(s). Cross the Hi & Lo as usual between 80 & 100 (pretend the mid outs don't exist). Set the mids up as you wish. You have several possibilities. Duplicate the dual settings. Compress the bandwidth to cover only the vocal range. ETC
These are only a few of the total set-up options. Too many to attempt here.
And yes L/R out of board to L/R in on DRPA.
Also, you said that you have 1 sub. If that is the case, you'll need to move the crossover much lower and maybe run the tops full range. Unless that's one honk'n killer sub, it'll never be able to fill in what the 4 (6) 15's could do.
Let me ask you this, is the PA set-up wizard going to guide me through all this, or should I seek the help of an audio pro? I dont want to blow anything up!
Dan
With two 18's trying to keep up with six 15's, your crossover point will need to be lower than normal (80-90 for 15's). Let the top cabs do all they'll comfortably do and let the 18's handle the extremely low content. That may mean crossing closer to 60.
This a hard way to do it, hopefully you have the mic and can use the Auto EQ function outdoors and it will tell you what your cabs can do.
Also, can I just purchase a Pink Noise CD or download one on line to generate the pink noise?
Dan
The DRPA had a pink noise generator built in. You don't even have to hook up the mixer to do the tests. However, if you want a CD with pink noise and a lot more audio tools, click on \"Former Forum\" above and search \"Binks\". The first post from Lee has a link. Go there and download the CD.
Yes, auto EQ. Set up 1 cab outside, away from reflective surfaces with the mic 6-8 ft from the speaker. Point the mic between the horn and the top 15 (on the dual). Set the wizard to Flat / Med precision and follow the prompts. don't clip the input (it will tell you if you do). The EQ plot will help you see the response of the speaker. Use this to set the best place to set your crossover point. You can go back later and tune the speakers with the PEQ's.
Dan
Dan
What specifically have you done?
Do you watch the screen? What is happening (band wise)?
Have you checked the mic? Hook it up to your board and while someone else speaks into it you listen through headphones. Do they sound \"normal\"? I had a mic go bad and auto EQ went haywire (I didn't let it finish).
What is the next step? I completed the wizard and stored my custom 2x5 set up, now what?
Right now the dual 15's are working great, but the single 15's are only letting thru highs. They sound horrible. I assume that is because I told the DRPA that I have bi-amped speakers (Thats the only way I could set it up as a 2x5) so its only letting the high's through to that set. Can I tweak each set of speakers? Or, should I just abandon those single 15's altogether and use only the dual 15's as my mains?
Dan
Please tell me what speakers you have connected to which output and what the crossover is set to for each output.
Don't worry, we'll get there.
I have it hooked up as follows:
High output L/R from the DRPA into the QSC 2450 L/R out to the double 15 cab(s)
Med output L/R from the DRPA into the other QSC 2450 L/R out to the single 15 cab(s)
Low output L (mono) from the DRPA into the third QSC 2450 L (mono) out to the Dual 18 sub cab.
The PEQ's are a parametric EQ after the crossover and affect only the hi, mid, or lo outputs that are assigned to that output. These are used for smoothing out problems that the speaker cabinet has naturally. PEQ's have a smoother tonal response because you can adjust the \"Q\" to change a very broad or narrow range of frequencies smoothly and evenly.
Did you adjust the crossover so that you would have 2 sets of top cabs (hi and pseudo mid outs) and subs?
To smooth out the cab's response (if needed), set up the crossover at 80 or 90 hz. Outside away from wall buidings, etc... set up one top cab. Point the reference mic at the cab between the horn and 15\" maybe 10' away and run the auto EQ wizard. When it is done press the EQ button. It will show you what it did to get the speaker to a \"flat\" state. Go through and write down the areas that have been adjusted the most. Ignore the info below the crossover point. You may see 400hz @ +6, 500hz @ +5, and 630hz @ +5. Pressing the EQ button will scroll through the ouput PEQ's. Set one of the bands at 500hz that is wide enough (Q) to envelope these 3 regions and boost them + 5 or 6. Do this for the most extreme problems. You do have a limit of 3 for hi, 2 for mid, and 2 for lo. so choose wisely. After you have done this. go to the graphic EQ and flatten it. and re-auto EQ the same speaker. The response now with the newly set PEQ should show an improvement in the area that was showing a problem. You may need to adjust the \"Q\" or center frequency, but you should have an idea of the process. When you are done doing both top cabs in the proper output slot, you can then do a system check using one of each speaker including a sub. This will check the crossover point.
Get this far and report back.
I bought the DRPA mainly because I wanted a compressor. In other posts I have read that the DRPA compressor is a system compressor and doesn't function like a normal compressor. IE, tightening up my mix and allowing my singer to whisper and still be heard at a constant level. Did I buy the wrong piece of equipment? Should I add a DBX 266xl to get the compression I desire? Or should I return the DRPA and purchase a 260?
Dan
Hi Dra.. can I interject here...
Ok, whole system compression is not what you want to do here... Dra is trying to help you get your system tuned so you have no glaring problems that will prevent you from being able to get the kind of sound you CAN compress and not have problems with. Compression should be done on a per channel basis and NOT as a whole system processing thing... So the Driverack tunes the system and smooths the response so you CAN compress things and not have the system feed back, which it will do if the system is not properly tuned. Yes there is a steep learning curve and if you think that the Driverack can be hooked up and you push one button and everything is groovy .. well technology isn't that advanced yet. BUT the Driverack DOES offer you the tools to do the job. You have to learn what the different modules can do and how to implement them. If you follow Dra's lead and do as he says and read the information provided you will end up with a superior sounding system... but YOU need to do the homework, we cannot do it for you. We have provided all the info necessary to do this, I have personally provided the bulk of the info and steered many people to superb sounding systems but with power comes responsibility.. the responsibility to learn to use the technology. It's all here... Start in the \"former forum\", \"tutorials\" section, and \"user submitted white papers\" and read the info provided, there are step by step descriptions on how to do most of what the Driverack can do there. You WILL have to implement that info to your system though.
Be well and good luck..
Now I feel as though I am receiving somewhat of a \"dressing down\" from you and that I don't need. I am putting forth the effort. When I receive advice, I spend the entire day in the garage trying to go step by step according to DRA's instructions and it doesn't always make sense.
I guess I went off half cock'd and bought the DRPA based on some reviews I read. The cut sheet(s) I have read said nothing about the compressor being a whole system compressor, everyone said it's the best thing since sliced bread.
Simple question, can, or should I add an additional compressor to get the \"tightened up\" mix I am looking for?
Dan
Download the GUI for the 260 and play with it on your computer. While different than the PA in many aspects, it is very similar as far as function. This will give you a visual of whats going on, and may help greatly. Aslo do the tutorial that is offered for the 260 (kind of \"Video Proffessor\" thing.)
Graphic EQ
Crossover
Compression/Limiting
Delay
Etc.
So while this forum (and the former forum) will be a great resource for you, you also need to look for information specific to the individual components (or modules) of the DR.
As to your specific question about compression, think of it this way - you send the entire mix from your mixing board to the DR, not a single channel. The DR is processing that entire mix. It cannot pull out the lead singer's voice to apply the compression. So, anything the DR is doing is going to affect the mix as a whole. To apply compression the way you want, you would need to buy a separate compressor, and either put it between the mic and the board, or use the channel insert point on the board. The general consensus is you don't want to use the compression the DR. Use compression on individual channels to make them tighter.
In regards to the graphic EQ (GEQ) and the post-crossover EQ (PEQ), think of the PEQ as specific to your speakers, and the GEQ specific to the room. The PEQ is designed to make your speakers as flat as possible - no big dips or peaks across the sound spectrum. The GEQ will then adjust your now flat speakers to whatever room you're in.
Hopefully this makes things a little clearer. Don't ever feel bad about asking questions. I've had my DR for over 2 years and I learn new techniques all the time. I'm constantly tweaking my settings.
