Home dbx Forum dbx Forum Archive General Configuration Wizard
setup JBL jrx115
ianian
edited April 2007 in Configuration Wizard
I have a Driverack PA and have JBL jrx 115 system
Need help to configure the PA
  • Well, there isn't even close to enough info here for any kind of answer.. not to mention that all you need is a full-range preset, or bandpass such as the C300 preset. You have provided no amp info or any other system specs so what do you want?
  • ok this speaker we used with one crown xls 602 in stereo.... for the church
  • Wow Ian your just bristling with info aren't you... In the wizard use an all custom setup, and use the c300 preset. set the high pass end (lowest frequency you want to let the speakers get to)set that at 50 hz, use the hi outs. Read up in the \"former forum\" available above.. the tutorials and user submitted white papers, and the DBX training modules also above.
