Windows XP problem?
I have been using the Atten serial USB adapter on a Windows 2000 laptop for a 3 years and no problems.
The new laptop is the same manufacturer but with Windows XP.
Same USB adapter.
I have slow communication to the hardware and can do basic toggle functions like mute on/off but can't control parameters like EQ or delay.
I can load programs but it's VERY slow or will not \"see the network\".
The buffer speed and comm port baud rate has been adjusted up and down and still no improvement.
Thoughts?
Same USB adapter.
Thoughts?
Checked all settings I could find on another XP laptop with the same USB adapter and they are the same.
Disabled Norton Internet Security.
No change.
It's a if something is interfearing with the communication link.
Norton, possibly?
XP Media Centre, which my laptop was supplied with, is not quite like XP and may be incompatable with the drivers.
Jim is sending me an adapter that he has had good results with and I'll give it a try.
Failing that, my computer retailer is willing to wipe Media Center off install XP Pro and that should do it.
Probably a good adea anyway....
I'll post the results.
Hope all works great with the hardware change. I've been running XP Pro and have not had problems. BTW, are you using HotSync for the Palm? It really needs to be disabled before you connect to the DR260 if you are.
I'm sure tech support has gone through that iteration, though.
Take care,
Mikey
