crossover setup on driverack pa
What settings would be best for my setup (I need help)
3-way system with 2 EV 940hp horns pushed by linear tech amp, 2 Mid cabinets with 2 Eminence Sigma 15\" woofers each pushed by Samson 3200 amp, and 2 bass cabinets with 4 Eminence Sigma 18\" Subwoofers each pushed by 2 QSC plx3602 amps paralleled (System is Stereo setup) :roll:
gadget
1. set an HPF of 45hz BW 18
2. set an LPF of 100 hz LR24
thats the sube
3. set an HPF of 100hz @ LR 24
4. set an LPF of 2250hz @ LR 24
thats the mids
5. set an HPF of 2250hz
the LPF is not available on the DRPA so it is said to go to out...
Without a LOT more info about the boxes I can't be much more specific....
Do a good GAin structure as per the back of the manual, and then ballance the levels of the components (speakers) with the Amps input controls and or the XOVER gain control...
Delays I can't tell you without the speaker box info but just sweep through the available 10ms and see if there's a point where the speakers sound tighter..
should only need to delay the horn to the mid then add that to whatever the mid to the sub yeilds.
