Help me with the parameters, please
Hi:
I need to setup my system; I have four active speakers mackie srm 450 (two linked left & two linked rigth) and two subwoffer Cerwin Vega LR 36 (one left, one rigth) with a Crest audio 1200 amplifier.
Please, anyone show me, step by step the parameters to be input in the configuration wizard.
Thanks a lot in advance.
Power everything on in the proper order.
Hit the wizard button.
Answer the questions. Stereo/mono
Select Custom in the speaker selection
Select Custom in the amps
Tell the PA whether you are bridging any amps.
Go back to the wizzard main screen and start the eq wizzard.
It really is pretty easy to set up.
If you use the wizzards EQ settings make sure you use it only as a guide.
After the wiz does his thing put on some music you know well and tweak the settings to your liking.
good luck
