How to determine delay times
Just got the DRPA and love it. I have one question. How do you determine how much delay to use between subs and tops. I am using EV SX200's for the tops and EV T18 subs. The T18's are folded horns. Is there a good way to measure how much longer the sound from the subs takes to go through the folded horn so I can set the delay for the tops correctly.
Thanks for the help.
  • you would sweep the delay on the tops till it sounds best.. you don't jahve a lot of delay I figure you'll end up about 8.5ms.. 7.5 ms for the crossover delay and 1 for the not so horn loaded subs...
    gadget
