DRPA help Configuring with this setup....
edited November 2006 in PA Configuration Wizard
Can someone tell me how I should set the DRIVE RACK PA for the following setup:
6 JBL EON G1 (15 inch) Powered speakers daisy chained together coming out of the high output of the drive Rack PA
1 JBL MPRO 418SP Powered SUB with the satellite speaker....
the G1's asre flown up in the ceiling on a trussing system and the MPRO and satellite speaker are on the floor. What I need to know is what speakers so I select on the wizzard for the G1's? only G2's are listed in the wizzard. I did see the MPRO listed.. what setting to I set the levels at when it get to that point in the wizzard. Also is there anything I should do with the limitor or cross-over. We have DJ's here that like to turn up the bass on the mixer and I want to make it so they can not BLOW the sub as they have done that already 2 times. I dont think the person who was in chathe before has the DRPA configured Correctly..
Thanks for all of your help...
__________________
