Monitor mix???
edited September 2006 in PA General Discussion
Hi?
I havne't hooked up the PA yet and was wondering:
The band has two QSC power amps. One for the JBL mains, the other for the Yamaha monitors. We also have a powered JBL sub.
Anyway, I was wondering if we could use two of the available outputs on the Drive Rack PA to EQ the monitors???
I'm a newbie to this so bare with me........... We are currently using a separate EQ in the rack for this purpose, but if the DBX PA can handle the chore, well why not?
RR
  • No, sorry. The DRPA EQ functions on all outputs simultaneously. You can't specify a specific set of outputs.
    I believe the DR 260 can do that however.
    C
  • I understand they run simultaneously, but does that mean you still can't EQ the monitor amp (just like it was an amp used for another pair of mid or hi mains)?
  • If you used the Hi outputs of the DRPA you would have a three band PEQ to use...
    I don't have my DRPA handy, but I believe if yoy select dual mono you might have separate control of the GEQ as well..
    use the xover control to set up a bandpass for the monitor feed..
    page 39 has a block diagram that shows what functions are tied together.
