Serial Connectivity through Ethernet?
I'm curious to see what pins the 260 actually uses within the DB9 cable. I have ethernet ports that were installed running from my FOH to the stage breakout, however, I dont know if 1. The serial signal will even travel the 150+ ft. , and 2. If it will work if I wire the used pins on the DB9 to an ethernet jack.
I know I could get serial to ethernet adapters that will work, but they're also pricey.
Any advice would be appreciated.
