Using 2 amps for subs
Hi, I have just aquired a DBX Driverack PA. I am using 2 Crown XLS 402 amps for the subs, both amps are in bridged mode.
My question is how do I set up the LOW AMP Bridging in the DRPA? I can't change it from normal in the setup wizard.
BTW I am driving 1 JRX 118 sub (4 ohms) with each XLS 402.
Any help would be greatly appreciated.
Beau
Beau
\"I can't change it from normal in the setup wizard.\"
Yes I have my 2 CrownXLS amps set up for bi-amp. Each amp to drive 1 sub.
In the setup wizard, you go thru pages, main spr., sub spr., hi-amp, hi amp level, low amp,low amp level, Amp bridging (which is set to normal). Should it not be set to bi-amp? I cannot change it from normal.
Also on another note: I keep reading the JRX series speakers are not in the wizard. Well I have them in my DRPA!
Have a great day,
Beau
