Phase alignment
Ok here we go...
Just bought a brand spanking new system consisting of (all Yamaha) 2-CW218V, 2-C215V, QSC4050HD(onsubs), and QSC1850HD(on mains). Wow!!! I think this is one of the best sounding systems I have heard in a while, but I am never satisfied, and just want to see if I am on the right track? All of my speaker cables are speakon at the amp end, so I am unable to reverse polarity to make the necessary adjustments in delay. Would I be better off to?
A) Carry a Banana to 1/4 cable to make my adjustments and then switch over to the speakons, or...
Make a short Speakon jumper that reverses the polarity and remove it after making all adjustments?
In answer to you either/or question:
None of the above :shock:
Buy or make up a polarity reversing male xlr to female xlr cable/adapter. Simpler to make and readily available for purchase. Invert the polarity on the FRONT end of the amp. This adapter can come in handy if you don't have polarity switches on each mixer input, like for bottom snare micing or dual opposite kick drum head micing.
If you decide to make your own, get enough parts for a couple AND for a few, male to male, female to female, and lifted ground adapter cables. They all come in handy 8)
Mike McNany
This is before 'Xover', Eq's, Delay's... :shock:
understanding hf polarity requires a bit more, sice you can't see the diaphram move. You need a tool, or at least the MFG spec.
I think you misunderstood the OP's polarity reversal's reasoning. AFAICT, he's looking at using the reversed polarity to find the optimum delay. I.e., adjusting delay for maximum signal loss around the crossover point with polarity reversed between tops & subs to find the optimum delay.
NOT for testing speaker polarity.
Mike McNany
No, I have this as a test setup for multiple purposes... Thats what I was saying, it makes it easier to do the battery check.. and for the delay purpose it would work also...
With the DR260, you can do so, with the push of a button. That also has the benefit of being, PRE - amps, but wasn't put there for that specific purpose, has more to do with the speaker tuning aspect...which spills over into usefullness where aligning the speakers components is concerned. The important thing is to reverse the polarity and listen for a null...there may be several. It doesn't matter how you do it as long as it gets done... there are easier ways to do it, but usually require lots of knowledge in acoustics, and measurement technologies (Hi Mikey)
Oh well...you get the the idea...
Wow, its my birthday :roll:
Thanks All
