new user
Gadget could u please tell me where to set my attenuators on my power amps.I own a older mc2404 with 4 JBLmp418sp,2 JBLmp418s,and 2 JBLmp225.I would also like too know where to set my amp sensitivity\"in the wizard setup\" Would it be 0.775 volts?thanks for your help willy
If you don't have a spec for the input sensitivity, Do a gain structure on the system and see where things fall...You list the MP418's twice:
\"4 JBLmp418sp,2 JBLmp418s,and 2 JBLmp225\"
is that 4 each, 418's with the 2, 225's, and a smaller rig(same system) 2, 418's with the 225's?
so many questions...
please go speaker by speaker and amp by amp amd all corresponding equipment and connections...You still failed to see what powers the tops, and the unpowered sub?subs?
Lots of info please
From the Crown site:
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
So looks like 1.4 volt sensitivity.
If you have the GUI you can see graphically what I'm telling you. All the equipment you have is in the wizard. If you simply select what equipment you have in the wizard it will automatically set the sensitivity.
Can you explain to me what's going on in this thread? Am I supposed to be setting something in the DR260 to match my input sensitivity?
This is the spec on my amp: 1.23 V (+4.0 dBu). What am I supposed to do with it?
Is this something I do on the input mixer in driveware?
Thanks in advance!!!
That is the input sensitivity setting on your amp. In a perfect world you would set that amps sensitivity to the spec(the driverack actually shows the clock position for these if the amp is in the presets, in the GUI) and then use the driveracks crossover and output controls it set the system up. Problem is, in a system thats not matched, it makes doing the gain structure that much more difficult.
I suggest that if you are a beginner or novice that you set the gain structure and let the amp levels fall where they may...
What I'm going to do is provide you with a post by Jon Wilder, and some other homework. Here's the location of the thread, in the 'tutorials\"section:
http://www.driverack.com/drug/
Here is the thread:
http://www.driverack.com/drug/view_thre ... d_id=40803
There is a lot of good info there...
And the homework...
http://www.prosoundweb.com/studyhall/
This is the Prosound web \"study hall\". A wealth of information...It should keep you busy ...for a ..while
There's more if you want it, and I'll be around when you have further questions...
