Peavey
I am using three PV 2600 amps, one stereo running 2 jbl mp415s per side and the other two, bridged mono, each running a Peavey SP 218 sub. Are there any configurations for a set up of this size and make?
  • Hi
    Ive been hampered by a malfunctioning computer... :x and haven't been able to get the information from the Peavey site. Perhaps you can... go to the manual and check the specs... also have a look @ the frequency response chart for suggestions.
    Not really rocket science... :wink: I'd suggest starting with a 40hz HPF @ 18 db/oct BW, LPF @ 100 hz L/R 24. for subs :arrow:
    For tops I'd suggest L/R 24 @100hz with OUT as the LPF , with a 7-8 ms delay. :arrow:
    I'd set up a 2x3, using 'custom for the subs and amps.. use the presets for the MP415's... Do a basic balance setup then a good Gain structure... :!:
    I have also heard you can go to the Peavey forum and ask there also.
